anticubicle
- Joined
- Jan 21, 2008
- Posts
- 718
- Reaction score
- 2
From your first post, I am not sure how much power. Its stock.
Well, think ahead to what you WILL be making. You're installing the Nitrous kit right? Make a guesstimate!
Correct the power level you plan to get to can make a real difference. I have been from the stock 3.55 to 3.73 then 4.10 then 3.73 again and now thinking of 3.55 again, so think long and hard unless you swap the gears yourself then buy my 4.10 and ck them out . LOL!Well, think ahead to what you WILL be making. You're installing the Nitrous kit right? Make a guesstimate!![]()
How much you asking for them? And are they FRPP?Correct the power level you plan to get to can make a real difference. I have been from the stock 3.55 to 3.73 then 4.10 then 3.73 again and now thinking of 3.55 again, so think long and hard unless you swap the gears yourself then buy my 4.10 and ck them out . LOL!
I totally disagree. There are many 4.10s + autos running in the 10s. The only reason I would switch to 3.73s is if I was trapping over 135mph. But at 128-130, they are just right.IMO 4.10 are to much for an auto car
My 4.10 exp was with a 26" tire .Don is right, especially if you run a large diameter wheel. A larger diameter wheel will effectively make your gear ratio taller (higher gear lower number). In some cases a 28" tire can take 4.10s to an effective 3.90 ratio.
Hope this helps.
Mike
The link is in my sig.How much you asking for them? And are they FRPP?
Oh yeah, then 4.10s are way too much! Talk about winding the piss out of it on the freeway!My 4.10 exp was with a 26" tire .
if you go turbo i would keep the 3.31's. I have 3.55's in my car running a turbo.
BUT, I do plan on going turbo, and w/ my TR6060 gearing will go with a 3.73 or 3.90.
Again, unless your getting the turbo next month... get some fun gears and enjoy your damn car...
it is just a damn car.... drive it!
Dont save it... someone will steal it, wreck it...
Me and ron have a tr-6060 with 4.10's we wouldn't go any other way point end of discussion. with the tr-6060 your first and 2nd gears are much longer. With 4.10's you wont get full boost in 1st but hell you wont either with 3.55's. with 4.10's you will have higher acceleration than with the 3.55's. Also having a two step helps you to build boost from the hole.
Andrew
Andrew
Andrew
Ahem... last I checked, this thread was about "what gears for an auto trans". So any discussion of 6060 or 3650 is of no value.Ron doesn't have 4.10s
and you don't have a 6060![]()
Is that one better than the t56? I have never heard of it.6060 = 6-sp manual
