NHRA rule change
Seer
I doubt that "unaltered" will mean factory tires. Do you expect the tech inspectors to know the OE tire on every car made? Just my guess, but I would think that any DOT tire would be considered a "service replacement".
I'm not even sure how you define a DR in a rule, treadwear rating? That's how SCCA does it.
Sent from my Nexus 7 using Tapatalk 2
Probably not, if they are DOT Drags. Tires are a wearable item, so I doubt they play into this rule. But in certain levels of auto crossing, changing the tire compound does move you from class to class. I don't see why it wouldn't play into account in NHRA racing.
mrnoodley
SCCA has 3 classes of tire:
Street Tire = DOT & treadwear over 400
DOT Tire = any tire with a DOT rating (equivalent to a DR)
True slicks
I'm not a drag racer, I don't know if NHRA has a true street tire definition. I'm not sure how you'd distinguish between a DR and the tires that come on cars like the ZR1. The factory tires are almost slicks from the factory.
You can't just say that tech inspection will know it when they see it, you'd need a definition.
This leads me to believe that "unaltered" does mean chassis (firewall, wheel tubs, etc.). It could mean no power adders, but if a GT500 is safe @ 135, why wouldn't a GT with a blower?
Marc s
NASA AIX
Auburn, WA
If you have an 06/07 that is the same as an 08/09 and you put 08 on your tech card do you think they are really going to check the registration to confirm the year? I guess this will all depend on the track and the inspectors.
Tech will not look at the registration. It won't matter though. A stock 07 GT500 on stock rubber will never run quicker than 11.50.
Yesterday, I had the NHRA call me about some chassis certs so I asked him about this new rule. They said, the car has to be on OEM tires and be 100% stock.
fdjizm
Drag Queen
^knew it!
Just to accommodate the newer factory cars.
Seer
So then basically, this is for the GT-R and the occasional Z06/ZR1 with some exotics sprinkled in. But I am thinking the main motivation behind this was the GT-R.
fdjizm
Drag Queen
I'd say godzilla played a strong role with that effortless launching. lol
Seer
I've been around the 2013 GT-R a lot lately. It does not take much skill to get a bone stock one to run 10s. With it's ability to cut 1.5X 60's on its stock street tires. It's really cool how the car changes its torque bias from AWD on the launch, to pretty much strict RWD once it is in motion.
psfracer
billy badass
Valencia, CA
I think its going to be up to the tracks, in the end, on how they enforce it. At Irwindale the tech guys were saying as long as there are no modifications to the engine, on a DOT legal (not oem) tire. So while obviously you would be correct, as your info came directly from NHRA, my only point is it may be implemented differently depending on what track you go to.
OR--you go through tech on your OEM tires, then switch to a dr on a spare set of wheels in the pits after tech, then get in the lanes and I almost guarantee no one is going to be called out for that.
mrnoodley
It'll be interesting to see how the tire issue works out.
What if OE tires aren't available when replacements are needed? What if the OE changes OE tires midyear? That happens often. Are tech inspectors supposed to know when this change was made and compare VIN to the tires?
Opens a big can of worms. NHRA is going to have to officially clarify what "unaltered" means, especially the tire issue.
Sent from my DROID BIONIC using Tapatalk 2
Seer
On race days I know tech inspection is more anal. TnT days... be lucky if they even make sure your battery isn't loose at the tracks I run at.
fdjizm
Drag Queen
Till manufacturers start putting tires like this on a car...
I don't think it's hard to tell the difference between that and a street tire, especially if you work at a track and see the stuff everyday.
cm581978
NJ
I'm sure GTR owners are breathing a sigh of relief. Considering the 2013s run 10.8s bone stock, I was starting to wonder if dealerships were going to throw in a free roll bar with each purchase.
BMR Tech
Traction Vendor
Tampa, FL
I will be completely shocked, and actually dissappointed in the NHRA if "unaltered" means 100% stock down to the tires.
- Is a 10 second car safer on street radials than DR's? No way.
- Is a 10 second car, 100% stock, safer than a pulley/tune/suspension car on DR's? No Way.
If anything, suspension and Drag Radials will enable the racer to be more confident in his/her actions and be less prone to hitting the wall due to a crappy track. I have lost traction on the 2-3 and 3-4 shifts at a track on street radials, and it's NOT fun.....even in the 11 second cars I was driving...
Seer
I will be completely shocked, and actually dissappointed in the NHRA is "unaltered" means 100% stock down to the tires.
- Is a 10 second car safer on street radials that DR's? No way.
Not to mention, you don't want to be "that guy" who spins through the first few gears chewing up the track prep in the groove, lol. But again, most of us feel this rule was made for the GT-R, and that car has ZERO issue cutting 1.5X 60's on regular stock street tires. I can't go to a track outting and not see at least 2-3 of them there.
psfracer
billy badass
Valencia, CA
Thats basically what I am saying. If you go to an NMCA event, chances are they are going to enforce the new rule to the letter.
On a regular TNT event--I am sure they are not going to care about a DR, and won't even check the rear suspension for OEM parts--but I can see them making you lift the hood just to make sure the engine is completely stock.
BMR Tech
Traction Vendor
Tampa, FL
But, what I wouldnt understand is....how is an engine modification even being close to relevant when speaking of 10.00 or slower? (safety)
A stock 2008 GT500 with only a TVS upgrade w/ 14 psi is not going to be any more dangerous than a 2013 GT500, completely stock.
psfracer
billy badass
Valencia, CA
One is factory, with all of the engineering and testing and approvals behind it. The other is not. That is the only difference I can think of---as mentioned earlier in this thread.
mrnoodley
I'm not saying that tech inspectors don't know what a DR is, or how to spot them. I'm saying that if they're not allowed, you have to define in the rule what a drag radial is.
There's also a huge difference between an NT555R and a Hoosier DR. Where would you draw the line?
ZR1s are available with Pilot Sport Cup tires from the factory. They're a competition tire, not a DR, but they're damn sticky, probably as good a drag tire as a 555R. I wouldn't be surprised in the future to see the GT500 or ZR1 come with a DR from the factory as part of a "drag pack" or something.
mrnoodley
Are ewe all readong too much into this? The rule that we're all talking about is for the "Street Legal Style" class. Does that really change anything for TnT days or any car not racing in that class?
