Sway Bars w/ Whiteline RLCA Relo Brackets?
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
you make a lower control arm with an L shape, and a reinforcement that goes from the axle part to 3/4 the way down the main beam so the weld area out back doesn't collaspe. would correct the angle. drawing is a bit exagrerated as you would want the lca's level for road racing.
No, this would do precisely nothing. The pivot points are still the same, therefore it doesn't matter if the arms are straight, "L" shaped, or made out of unicorn horns.
The only way to correct the geometry is to relocate one or both of the pivot points, which is banned under SCCA rules.
DILYSI Dave
Braselton, GA
on the stick axle too, it specifically says you can only change the location of the upper control arm on the axle side. its been covered several times that lca relocators are not legal..... unfortunetly...although a lca could techincally be designed to correct the angle.... think ladder bar shaped attatching at the top rear....
16.1.E - Suspension components are unrestricted as long as they use the original attachment points. For the purposes of this rule, “suspension” is defined as any item that is designed to move when a wheel is deflected vertically. This includes shocks/struts, control arms, steering knuckles, uprights, etc., but not tie rods, steering racks, and subframes. In addition, shock absorber/strut upper mounts are to be considered suspension components.
The intent there is that chassis side attachment points remain stock. In Street Modified, you can use LCA relocators, etc. The UCA allowance you are thinking of comes from Street Prepared - 15.8.I.4 - "The upper arm(s) may be removed, replaced, or modified and the upper pickup points on the rear axle housing may be relocated." In SM though, the sky is the limit outside of those attachment points. If you could figure out a way to install an IRS and only do it using the original pickup points, that would be legal.
One of the benefits of getting more eyes on this stuff though is that it brings to light other interpretations. Would you mind writing a letter requesting that 16.1.E be clarified to read "Suspension components are unrestricted as long as they use the original chassis attachment points"?
Norm Peterson
corner barstool sitter
RIP - You will be missed
The force should be enacted through the line between the two bolt holes.
This. Sort of.
There's a minor exception that I'm pretty sure is SP/ST (and hence SM) allowed already, that being offset bushings which allow the arms to pivot about points slightly different from the bolt centers. There's even an allowance to pin the bushings to fix their positions, so long as there are no other benefits by doing so.
As long as the arms must remain OE, there is a limit on how much potential benefit exists. I'm sure that you could get somewhat more creative in SM.
Norm Peterson
I doubt it adds much, if any, to the strength of the chassis in any load direction other than straight through the bar.
It's about stiffness rather than strength (which is generally related but not necessarily in linear lock-step).
After that, I'm guessing it depends on whether you're wearing an engineer's hat with the intention of staying within the spirit of the class, looking for an "unanticipated" advantage, or playing lawyer.
There probably is a minor stiffness benefit even if only the current WL frames and OE bolted attachment points are used. I have absolutely no idea how much it might amount to, not even an order of magnitude guess. Never mind what you might be able to accomplish with a custom, one-off frame.
That said, at least what is currently commercially available feels like it is within the spirit of ST/SP.
I only got my Fastrack notice this morning, so I haven't thought too much on this yet.
What does occur to me is the situation where somebody stick-welds a bunch of steel to a greasy OE diff cover and then proceeds to apply huge WL loads to it, loads that the cover itself was never intended to be carrying either for magnitude or direction. You could end up seeing all kinds of low-$ hack jobs with no engineering behind them whatsoever that would be class-legal. The first downstream concern that comes to mind is fatigue cracking and the risk of dumping a diff full of lube on the course. It sounds like penny wise / pound foolish logic to disallow replacement covers that actually have some history on which to assess a potential reliability matter that would directly affect the smooth running of an event.
JesseW.
Panama City Beach, Fl
But 16.1.E does not say chassis, which leads to my intreptration that if it does not say it, its not allowed.
E. Suspension components are unrestricted as long as they use the
But maybe i will write a clarification letter on that. SM needs more stick axle cars.
btw, i didn't do so well in physics me ---> :dunce:
DILYSI Dave
Braselton, GA
AMEN! We even gave stick axles a weight break last year (-25 pounds per liter), but SM doesn't get much love from Mustangs. Ironic, as one of the contingents that lobbied heavily for it back in the day (15 years ago?) was Mustang folks who wanted a place to run with sub-frame connectors.
JesseW.
Letter wrote:
"E. Suspension components are unrestricted as long as they use the original attachment points. For the purposes of this rule, “suspension” is defined as any item that is designed to move when a wheel is deflected vertically. This includes shocks/struts, control arms, steering knuckles, uprights, etc., but not tie rods, steering racks, and subframes. In addition, shock absorber/strut upper mounts are to be considered suspension components."
Is that attachment points talked about on the Chassis Side or Chassis and solid rear axle together? Since a solid rear axle is considered a "suspension component" as it is deflected vertically, it would give me thoughs about being able to run lower control arm relocators on the axle side to correct geometery from lowering the vehicle. About in the same way Independent Rear Suspension cars can run longer ball joints to correct the lower control arm angle on those cars.
So i would request either clarification on the rule and if it is so we can run relocators on the axle side to change the first sentence to "Suspension components are unrestricted as long as they use the original CHASSIS attachment points."
As far as the -25lb per liter for the stick axle, i wish they would have made it a +25 lb/L for the IRS guys. My minimum weight with a supercharged(+1.4liters) 4.6 is 2850 lb. there is no way i can get there. 1800lbs+(200lb*6L)=3000lbs 3000lbs-(25lbs*6L)=2850lbs No way my car can get there with half an interior heater and other stuff. last year the car weighed 3440lbs at the dixie tour. this year i'm hoping its under 3400, but there just isn't another legal 500lbs to pull out of it.
if it were a +25lb in the irs guys, the common 240sx with an sr would be 2565 lb making in the 350 to 400 whp range. those weigh 2700 to 2800 to start with so they could still do some weight removal without having to gut everything out of the car.
btw, Dixie tour usually has a few mustangs in SM because we are all just fun loving rednecks down here, lol. already has my car, a 600 hp GT500 and a heavily modded fox body signed up for SM.
DILYSI Dave
Braselton, GA
Hell - I may have run against you at Dixie. I used to have the Green and Blue Civic. Technically an SMF car, but when we couldn't get a full SMF class I would run it in SM. I know I've run against Rob and his Fox body a few times. I had the lead on day 1 a couple of years ago, but let George Bonefede get past me on Day 2.
JesseW.
Last year was my first there. George crushed us in that GTR. Glad to see he's running STX this year. the GTR has a SSP pax of .877 and a SM PAX of .867. he can move up to SM and get a better PAX, go figure. i was about a 1.5 behind Rob after 2 days, so around 7/10's a day. i have my suspension a little better sorted this year with appropriate spring rates instead of eibach pros, so i'm hoping to be running time comparable to rob's. if not its still a lot of fun.
Vorshlag-Fair
Official Site Vendor
Dallas, TX
Terry's tizzy aside, he did something illegal, several people told him it was illegal, he disagreed and asked for an official clarification, and it was clarified as illegal.
Wrong, Dave. I didn't do anything illegal. YOU say it is illegal, and you have helped to re-write a rule that has been on the books for decade or more without debate or protest. Let's not call someone a cheater when it is all based on an arbitrary opinion of about 5 guys on some committee. The actual competitors in the ESP class had no problem with the Whiteline or 6+ other brands of Watts Links that replace the diff cover to mount the propeller.
The explicit UNRESTRICTED MOUNTING meant UNRESTRICTED, to me and everyone else I asked that actually races in ESP. I ran the car like this and showed the world the parts before Nationals, with our very public build thread ("many hundreds of thousands of page views" public). We had a couple of arm chair quarterbacks like you on the sandbox (which we mostly ignore), and then it was mentioned here by BIG Sam (who, let' not forget, is a direct dealer with Fays2 and has a vested interested in protecting this brand), but ALL of the racers we talked to that actually race in ESP had no problem with it. Because it wasn't even a question of legality - it is the most common sense mounting arrangement for any Watts Link system built by the aftermarket.
That was the problem we have with the SPAC and SEB... they don't seem to understand many of the parts and systems written about, that they rule on. We talked to some folks on these committees and they admitted they had no idea what a Watts Link was or did. "Respectfully", I think these rules committees are missing a lot of experience and knowledge of systems like automotive suspensions, engine tuning, engine building, tire technology, and on and on. There is almost nobody from the aftermarket industry on these committees, and the only ones that were have become fed-up and left in disgust. Or are there to protect their turf.
Nobody said that the diff cover is a performance advantage.
Wrong. It came up on both the SPAC and SEB calls, unless committee members are lying to us. First they argued that if cover swaps were "allowed" for Watts Link swaps, alternate diff covers would sneak into CSP Miatas and the like. WTF?! They had no idea that this rule only applied to solid axle cars (rolleyes). Then it came up as bearing heat and performance advantage. I'm not making this stuff up, Dave, just repeating what was discussed. You guys need to get your story straight, Dave.
Just said that there's not an allowance to change it.
THERE DIDN'T NEED TO BE AN ALLOWANCE. THE UNRESTRICTED MOUNTING RULE COVERED THAT.
And the way the rules work is that if it doesn't say you can change a part, then you can't.
Wrong. The wording used previously covered all sorts of allowances for Watts Links, both cutting and welding and custom fabrication. It was wide freagin open. The only thing that changed was the members around when this Watts Link rule was originally written are probably long gone, and this new lot of volunteers apparently had no idea what a Watts Link was... and they fumbled around and argued themselves into a corner and decided to obfuscate and meddle and changed the rule.
In fact, despite performance being sited several times, in quotes even, in Terry's rant, here is what the tech bulletin said...
BUZZZ! Wrong. Doesn't matter what is printed in the bulletin, that isn't all that was argued. It never is. Until your committee calls are recorded and published for the members we will NEVER REALLY KNOW what went on in these debates. Only what you want to tell us.
He's right - sometimes things take too long. Some of the minutia is frustrating, and leads to a rulebook that can be cumbersome.
You guys take 4 years to decide what color to make the SCCA Solo logo, ha! #massiveunderstatement
And despite ALL OF THAT, Terry competed in a car at the national level that was illegal, and nobody gave him shit about it. It's hardly the weenie convention that is being portrayed. Lots of people looked at the car, decided "well, that's illegal, but he didn't beat me because of an illegal watts link - he beat me because he out-drove me" and let it go.
This is nonsense, Dave! You are changing history. NOT ONE competitor in my class said a word to me about the Watts Link. Only a couple of random voices on the Sandbox and BIG Sam here, who has his own parts to protect (ulterior motives).
And if Terry chose to compete this year with the same parts, I'm betting the same would happen again - particularly with the a proposal on the table to specifically make him legal.
It will take 1-2 YEARS before your committees can wring your hands enough to make a new proposal into a rule. I'm not going to wait 1 to 2 years and run craptastic alternative parts in the meantime. OR make a tortured OEM variant of a cast aluminum cover that serves the exact save freagin purpose!
(someone mentioned that we could bolt the WL cover over the stock stamped steel cover)...
That would be legal.
You do realize how stupid your clarification is then, don't you Dave??? Obviously not, but let's go on to more asinine ideas...
The better way (ie, what I would do if I were doing it) would be to take the pivot mount from the whiteline, which is already steel, and cut a few pieces of filler of the appropriate size, and weld it all to the stock steel cover, effectively duplicating the geometry of the whiteline cover. A few hours of fab and it is 100% legal. Not ideal, but not worth a whole lot of hand wringing either.
I sure am glad you aren't building my car, Dave the SEB member. Dave the non-engineer. Dave the non-fabricator.
That would be a short lived stamped steel diff cover. The OEM cover that came on my Mustang is made from 14 gauge stamped sheet steel and would rip itself to pieces in minutes. #theseguyswritetherules!?
No, the better "stupid SCCA idea" option would be to take one of the FOUR cast aluminum OEM S197 Mustang diff covers and weld more stand-offs to that, custom machine them to fit the WL pivot bracket, then put this monstroucity onto the car. Yes, it would be a KLUDGE, yes it would take $1000 worth of custom fab and machine work, and NO it wouldn't be as elegant as the included WL diff cover... but this is the kind of nonsense that we have to go through to meet the ever-changing letter of the rules from the SEB.
Ricockulous.
That is the word that best describes the tortured process many racers have to go through to make parts legal within the arbitrary, illogical ruleset that makes up SCCA Solo.
If it doesn't make sense, it must make Money
That is the one thing that keeps popping up in my head when I try to understand why and how you SEB boys came up with this latest rule change. Who does it benefit? It damn sure isn't the racers, as now 70% of the aftermarket Watts Link choices are now illegal. They can call up BIG Sam and use his janky, clanky Fays2 unit, which should never be used on a street car (*Bang! Clang*). Virtually every other option just became "illegal". And the Fays2 costs the same as all of the rest.
So you aren't saving people money, you aren't making it easier to compete, you are making it harder. And for people that don't want the janky rod-end equipped unit that is legal they then have to spend a lot more TIME and MONEY to make the bolt-on kits legal to this new interpretation.
Make it Easy, Make it Fun
Somebody should post that on your steering wheel for you to look at every day, Dave. THAT is your job on the SEB. THAT sentence encompasses what you should be doing. NOT chasing away competitors and aftermarket suppliers and potential SCCA sponsors. Because THAT is all you are accomplishing now.
Good day to you too!
PS: This isn't over, Dave. We're taking this to the BOD, and so is Whiteline. I am not letting this go away quietly. This is an absurd over-reach by the SEB that doesn't benefit the members or competitors in any positive way!
JesseW.
Terry,
why must you get so mad? you wrote a letter asking for clarification and the board gave you a response you didn't like and now you're blowing up all over the internet at people because it somehow proved them right? i know it takes a while in the SCCA to get thing done, but you seem to totally ignore the fact that they asked for member input for allowing aftermarket covers, that would take into account the watts link diff cover. maybe it'll be next year until it passes, but so what? no one else can use the parts in question for the rest of the year. Equal footing for all.
First you complain about the SCCA changing the rules every month then you say you are taking your car and going home because they don't rule in the manner you like, but are trying to accommodate your parts next year. I understand your business revolves around whiteline or you wouldn't be pushing it so hard, but it makes me wonder if you have signed some sort of non-compete clause saying you can't use another product. (or just protecting your supplier like you accused Sam of)
You've been condescending to the point of name calling to Dave, Sam (who both have been on the SEB and knows how it works and what they look for, unlike you), the SCCA, parts made by other manufactures which work and meet the rules, although not in a way that you would apparently like. I was considering buying some parts from you (the mentioned whiteline watts after the SEB clears up the diff allowance) in the upcoming year, but I think i will go elsewhere.
And lets look at some "other facts" the Fays2 can be had new for $650. the whitelines i have seen from $900 and up. cortex is $900+, steeda$1000+, Lakewood $650+. so it doesn't cost the same as the rest unless you want to give me a really nice discount. Not only that, but rod ends are much better at keeping things in place than any poly/rubber/magic bushing that isn't metal and allow for less binding.
guys, lets debate the topic all we want, however, please try to keep personal attacks out.
Thanks
2008 V6
/I].
Actually - That is what I was going to do. The first option was to weld pads on the axle tubes but the tubes are soo thin & would be declared illegal. My axle tubes are already welded to the case. Decided not to do either at this time. Figure 10 to 12 hours of my labor to make my own watts link but don’t have the time & I lucky enough to be at a stage in my life where it is cheaper to buy an item than for me to make it. Everything on my car was either given to me or store bought.
The only thing I might do is modify my front lower control arms so I can get more caster. other than that - Why re-invent the wheel.
Every race organization has rules that squew some type of suspension, engine combo, add weight here subtract SHt there ECT, ECT, ECT. Everyone bitches when it affects their particular setup even if it is illogical. The problem now-a-days is that the rules can’t be interpreted easily. If it is not written, ya kant do it. It is all in the wording & usually modified by who ever sponsors the most $$$$$$. Hey that’s racing these days. Don’t like - Find another organization or start your own. IMSA - NASA - VARA - SVRA - Alpha club - Just to name a few who started for this reason. Most very sick of SCCA but use the majority of SCCA rules for a basis. Go figure that one. :thud:
19COBRA93
Ford Racing
Clinton, Ut
It's because the majority of the rules make sense. It's the rest of the rules that don't make sense that all the problems come from.
The priority should be that all of the rules make sense, not just most of them.
Vorshlag-Fair
Dallas, TX
Terry, why must you get so mad? you wrote a letter asking for clarification and the board gave you a response you didn't like and now you're blowing up all over the internet at people because it somehow proved them right? i know it takes a while in the SCCA to get thing done, but you seem to totally ignore the fact that they asked for member input for allowing aftermarket covers, that would take into account the watts link diff cover. maybe it'll be next year until it passes, but so what? no one else can use the parts in question for the rest of the year. Equal footing for all.
It is not equal footing for all. People that had used what everyone (except a very small minority) that didn't use one of 2 or 3 brands of Watts Links now has to remove their formerly legal parts and go build or buy an all new unit. For what? Did the old unit have some unfair performance advantage? Was it lighter? Was it benefiting the car in some other way?
NO.
The problem I have is that there never should have been a question, because the rule as written had more than enough room to include alternate diff covers. Because the mounting was UNRESTRICTED. See the rule below...
15.8. I. Solid axle suspension allowances:
1. Addition or replacement of suspension stabilizers (linkage connecting the axle housing or De Dion to the chassis, which controls lateral suspension location) is permitted.
2. Traction bars or torque arms may be added or replaced.
3. A panhard rod may be added or replaced.
4. The upper arm(s) may be removed, replaced, or modified and the upper pickup points on the rear axle housing may be relocated.
5. The lower arms may not be altered, except as permitted under Section 15.8.C, or relocated.
Methods of attachment and attachment points are unrestricted, but may serve no other purpose (e.g. chassis stiffening). This does not authorize removal of a welded-on part of a subframe or bodywork to accommodate the installation.
See where it says "methods of attachment points are unrestricted"? Well a whole lot of people, myself included, took this at what was written.
Then this week the SEB changed that to mean something completely differently. So this is a TAKE BACK. And TAKE BACKS suck.
And this isn't the first issue I've had with a bad call by an AC or the SEB. This is like the 500th. I've been getting more frustrated every year for the past 25 years. I've just had enough. Enough of the clueless rulings, illogical calls, and ulterior motives behind some committee members.
While it seems inconsistent that I bitch about constant rules changes, then bitch that they don't do them fast enough. But you don't understand the situation here. This was a request for a simple clarification. On one word. Which has a very simple definition. Now they say they agree with me, but... it'll take 1-2 years to "fix the rule". When it never needed fixing, it just needed a simple clarification. That they screwed up for no reason.
The problem is they are NOT consistent in their rulings. The use the same arguments to both defend or strike down rules (airbags can be removed from seats in ST cars... but not steering wheels?). They take FOREVER to fix a blatant screw-up or mis-typing. Then other times they make wholesale changes or new classes without following their own guidelines. It is baffling.
Just don't think that I'm the "bad guy" here, or that the SCCA is always innocent in all of their dealings. The SCCA has been shown to have some very dirty dealings in the past and it cost them dearly. They had closed budgets for many years - until they were sued and lost. Ulterior motives and personal gain have bit the SCCA in the ass before. They've paid out huge fines and settlements on court cases in the past where they were doing some unscrupulous things (Formula Renault).
No, business reasons are not why I'm so upset. I don't have a non-compete with any other company, but that is immaterial. I'm so upset because this was a really bad call on the part of the SPAC and the SEB. They flubbed it, royally. The only reason I asked for a clarification was to silence Sam Strano, as he was whining online to protect the parts he sold to other ESP competitors (Fays2).
I am so upset because I bought a brand new freagin car to build a dedicated ESP Mustang with. I have already spent thousands of dollars on parts and labor to prepare it for ESP. And now that plan is totally f*cked because these SEB members don't understand what the definition of "unrestricted" means.
I have ZERO respect for Sam, as a competitor or a businessman. I am sure that spills over into my posts. But there's history there. Sam Straro is a devious little man who's been saying slanderous and unprofessional things about me, barely indirect enough to not look like a total douche bag to some (but many have noted it), saying unfair and untrue things about my employees and my business, on this forum for months. I've had some PMs with him and the site owner about his childish comments and behavior many times. Virtually every other vendor on this forum has had the same problems with Sam. Even most of his customers cannot stand him. Ask around.
Now SEB Dave is calling me a cheat, a liar and is himself changing the facts on things, which I also have no respect for. I've sent him a nice PM letting him know what I think about him as well. I've always had a smouldering disdain for the SCCA rules and I don't mince words when the committees make stupid call after stupid call. I've sent HUNDREDS of letters to the SEB over the past two and a half decades, even back when we had to hand write and to snail mail them in. Over these many years I have seen so little logic in the rules, and lethargically slow change when problems were noted and obvious and needed fixing. When you have spent more than half of your life fighting within one group it can become frustrating beyond belief.
Great, the Fays2 is cheaper. $250 cheaper on a car we'll likely spend $50K on is a drop in the bucket, really. But my problem is that the Fays2 uses rod ends, which are are terrible for street use. Anyone that tells you otherwise is lying or completely ignorant. Sorry, but that's the truth. Ride around in a car on the street with a Fays2 and you might be singing a different tune. You'll want to drive it into a tree. Its a pretty crazy set-up the way it clamps to the axle tubes... as a suspension designer and engineer myself I'd say it is pretty a terrible design. But hey, whatever floats your boat.
And there's one thing the rule about solid axle allowances that the Fays2 explicitly violates... "may serve no other purpose (e.g. chassis stiffening)". The Fays2 unit has a massive lateral chassis brace as part of its design. It bolts into the chassis laterally. It is clear as day to anyone that sees it. So I would argue that the Fays2 unit is the one that is actually illegal, to the letter of the rule, without question. But did that come into the discussion? Of course not.
I don't expect everyone to "like me", and I've got a lot of SCCA higher ups that don't like my input. If I would shut my mouth and "take it" I would probably make more SCCA people happy. But as a competitor, when I see something that stinks I'm going to point it out. And when they make a bad call I'm not going to back down. I'm going to re-submit the request over and over and over. I've argued some points about certain rules for 5-10+ years, but I never let up. Every once in a blue moon they make a logical call or update. Its rare, but it happens. If everyone just rolls over and plays dead things will not improve. If we say nothing they will meddle and crap-up the rule book to no end. I don't expect you to like that about what I'm doing, but some people get it and do appreciate it.
This isn't FUN for me, fighting over rules changes. It stresses me out to no end. I now have a brand new 2013 Mustang that now serves no purpose for me whatsoever. I buy these cars to develop new parts and to showcase parts that we sell. Now they just pulled the rug out from under almost all of the Whiteline bits, including a huge part of the rear suspension. I'm damn sure not putting the jankified Fays2 mess on my car. So I'm not going to participate in SCCA Solo for a while. People can say "he's taking his toys and going home." I guess that's fine. The fact is I'm taking my thousands of dollars spent annually sponsoring SCCA events away, and also not giving them many many hundreds of dollars in entry fees as a competitor to dozens of regional and National events each year. I'm not going to spend the $50K+ it would take to build what we felt would be a very competitive ESP Mustang with our 2013 GT. It is pointless now. This little "re-clarification" this week totally screws my build, it will cost me a LOT of money, and makes me sick.
Yay, nobody wins. :tdown:
Cheers,
JesseW.
I mentioned this a couple of pages ago on post #50, so why not show up with a phb and protest everyone, or write a clarification letter and get them all declared illegal. (i almost did this but decided against it as i can run about whatever i want in SM driveline wise). To me, the Cortex is the best unit, has roll center adjustment, rod ends on the prop side and looks well made. the whiteline unit looks well made, but doesn't have roll center adjustment and really doesn't need poly bushings on each side. the Fays2 unit, well i've personally seen one break the prop bolt at last years dixie tour and have seen pictures from a couple of others that broke them. i keep wondering just how much a watts link helps, everyone makes it seem like it transforms their car and they pick up a second on an autocross....
btw, i drive around with a rod end phb, its not bad at all if you lube them twice a year. I also check around ask numerous people and will write a letter if i'm wanting to put a part on my car and i'm not sure about its legality. that's one reason i'm not running LCA relocators right now (i've owned some for 6 months and ran them at a local event), no one has given me a clear yay or nay, but i don't sit around complaining about it. I get that you asked the ESP guys and none of them cared, but maybe you should have wrote a letter 1st for clarification. SP just had openings for their board, did you put your name in so you could have some say? it might have been smart if you want to get some positive rule changes.....
i like what they do with rule updates once a year and just clarifications throughout the year. it keeps it from being like nascar or the continental sports car series where they change in the middle.
i neither have the time, money, nor desire to turn my car into a full SM car where the rules are way more absurd than ESP... Fuel cell in trunk? go for it. remove heater?, carpet padding? trim strut hole? no way? i don't get the rules, but i stay inside of them. then again, i'm not making money at this either. Just running a National Tour is my favorite thing to do during the year and i'm going to try to make 2 this year.
also back on topic, BMR LCA relocators work with the rear Strano bars in all positions for those of you wondering. you just have to put them in, in correct order and have a couple of washers.
Whiskey11
SCCA Autoscrosser #23 STU
Terry, I've said it multiple times in multiple threads. I ran all last year on a Fays2 Watts link on the street for 8 months and about 8000 miles. The only time I had ANY additional noise was when a bolt came loose due to improper installation (read: MY FAULT) and subsequent tightening eliminated the noise. I'm not sure if YOU have rode around in a car with the Fays2, but MINE is dead silent. No clunks, no rattles, no squeaks, nothing.
I've had MORE problems with Sam's/Hellwigg's rear bar making noise due to a really poorly designed metal bushing sleeve that is a giant roll pin rather than a bushing that can be torqued against. Mine has split open like a flower and wont allow me to get the axle side bolt tight enough to stop it from making clunking noises. I plan on fixing that next year with a simple bushing spacer redesign. I need to call Sam to see if I can get two new poly bushings for the axle end mounts before I can do that.
That said, I respect Terry's frustration on this and I hope he can help find a solution to the problem for both SP and ST rather than spending his time belittling members of the SEB who ultimately make the decisions and those of us who chose other options. There is no reason we can't work together to find a solution. Terry, you can run Whiteline's PHB for a year, it wont kill you, or at least it didn't for the year you were in STX before you left us! :) Come back and play as I like chatting with you about your toys! :D
fun4me
Care to explain?
