TPS Slotted, Dimpled, or Cross Drilled Brake Rotors-from $259.99 FREE SHIPPING!
Dillon Dollar
oklahoma
Still not received mine yet how long does shipping usually take
Sent from my EVO using Tapatalk 2
tpsmak
Rotors are usually sent in about a week after the order is placed. Our supplier is a little behind because he had to shut down for 3 weeks..
I'll probably be ordering a set here in the next few weeks!
We'll be ready you you place your order :)
tpsmak
Bump...These are the best bang for the buck brakes around for your S197 :clap:
TGR96
el blanco nino
Huntsville, AL
Quick question, do you know if the cross drilled/slotted rotors can be "turned" on a brake lathe?
tpsmak
They can BUT it has to be done very slowly or you will chip the rotor or break the bit.
tpsmak
Spring and racing season is just around the corner! Who else would like to upgrade their brakes?
dalemllns
SLOMOD
Arab AL
how much for rotors and pads 08 GT and can you do an 11 Ranger rotors all 4? The ranger I will use a motorcraft pad if you have the rotors... Thanks
