Thanks for the heads up. Have to see how it works in my system. I can always remove the Krankvent form the PS line if I run into the same things you did. That's basically the way I was running it before my fire. Just thought I would try the extra Krankvent for a closed system.
Yeah, just set it up with removing it later in mind. For me, I had extra black Goodyear hose I got with my fuel system from Lethal. It was definitely affecting drivability. When I got off the gas, I could hear the first vent close, then the second one... almost sounded like an "echo"... so that was the first thing I tried when troubleshooting. Luckily, the first fix was the last. When does that ever happen??
Earl
