SoundGuyDave
This Space For Rent
- Joined
- Apr 9, 2007
- Posts
- 1,978
- Reaction score
- 29
I'm starting this thread to (hopefully) avoid further diluting Terry Fair's excellent build thread, and to break this fairly narrow (but fascinating) discussion into it's own, separate, thread.
So far, as a recap, we have a few things we are looking at, and that I would like to bring up for discussion:
1) The difference between inboard vs. outboard spring location, and how they impact rear axle wheel rates in both lateral and longitudinal loading.
2) How to calculate the approximate wheel rates for both cases.
3) Attempt to quantify "good" rates and splits through case study and example.
4) How rear roll center location impacts wheel rates, as well as general handling, particularly in terms of how adjustments to RC would affect spring choices.
1) Inboard vs. Outboard spring perch location.
First, we must work with the given values. Based on measurements from multiple sources, the axle-side spring perches are roughly 38.5" apart, the track-width is 62.5" to the tire center (8.5" rim, +45mm offset), the lower shock mounts are 52.5" apart, and the rear shock is inclined at roughly 80* from horizontal.
2) Calculating wheel rates. First, we must start with the motion ratios. The formula is D1/D2, with D1 defined as LRC (Lateral Roll Center) to spring perch center, and D2 as LRC to contact patch centerline. For simplicity's sake, I'm defining LRC as the center of the differential housing. If this is incorrect, I'm all ears! So, for the inboard spring perch, we have 19.25/31.25=0.616 for our motion ratio. For the outboard spring perch, we have 26.25/31.25=0.84, which is certainly NOT an insubstantial difference!
To get approximate wheel rates (not taking swaybars, bushing resistance, etc into account), I'm using the formula WR=(MR2*RATE)*SIN(spring angle). For the inboard case the spring is vertical, thus we can eliminate the SIN term entirely. Based on these assumptions, and using a nominal spring rate value of 300lb/in, we can then calculate the lateral and longitudinal wheel rates for both the inboard and outboard spring locations. I am also taking as a given a front motion ratio of approximately 0.95 for the MacPhereson strut suspension, with a corresponding wheel rate factor of approximately 0.90
Inboard: 114lb/in lateral, 600lb/in longitudinal
Outboard: 208lb/in lateral, 295lb/in longitudinal (inclined springs!)
Thus the inboard has a wheel rate factor of approximately 0.38 lateral, 1.00 longitudinal.
The outboard has a wheel rate factor of approximately 0.69 lateral, and 0.99 longitudinal.
We can start working case studies and extrapolations from here, but this will hopefully keep Terry’s thread clean.
