Bad Lash Adjusters=Valve Dropper
toorbeenee
turbine lunatic
dubai
i almost had the same problem,,i would check the guides if i were you
lito
Caracas, Venezuela
Yes I checked the followers. Nothing was damaged think god. Those things are priced like liquid gold. Lol.
I meant more that if you checked if they were working properly, I've been told of people having issues because of some not having proper geometry and giving issues, did or does your valve train is noisy?
Sent from my Nexus 7 using Tapatalk 2
strong_j
TX^SWAG
Wylie, tx
my valve train was a bit noisy, but i thought it was just my limiters. at the end of the vid is a clip of my valve train noise.
strong_j
TX^SWAG
Wylie, tx
Yea the 650's. that's what I thought too, but my tuner kept telling me it was just the lockouts.
lito
Caracas, Venezuela
Lockouts do not make any noise, there is zero movement after installed.
Never seen or tuned 650s myself and guess ramps may be steeper but I've seen 550s with zero noise issues so don't expect this for 650s, I would look the followers.
strong_j
TX^SWAG
Wylie, tx
Yea definitely going to take a look at them now. My cars almost finished and since it has turbo cams now if there is still valve train noise ill know what the problem is.
Off topic do u tune big stuff 3 lito??
lito
Caracas, Venezuela
No, never touched one but as almost every standalone tuning should be easy, specially as its VE, the thing is setting everything up correctly so the system works as expected. Good luck.
