ford20
I found this little bit of information. Apparently this was done on a Boss 302S. The Mods are listed below and the only thing added between the baseline run and the final run was the IM, TB, and the 123 MAF housing.
I will post the dyno graph later today as it is on my work computer or Mark if you have the copy I sent you , you can post it.
The increases are 30 rwhp and 20 rwtq with gains right across all rpm levels and it makes power up to 7800 rpm.
We will run it to 8000 once we install the high rpm pulse ring. All the dyno runs were done at the dealership on our Dynopack dyno and the tuning done by us with a SCT tuner.
The mods are AR 1 7/8 longtube headers , full 3 inch race exhaust with x pipe and a SCT tune . We used a temporary cold air intake for the dyno runs , we are making a permanent one this week .
Driveability seems fine but remember its a 302S so my street driving is limited to around the block trips.
The parts used are the CJ intake , CJ throttle body and the 123 mm maf housing
Tim
