CJ Intake Manifold Dyno Testing Results
ford20
White Plains,NY
I found this little bit of information. Apparently this was done on a Boss 302S. The Mods are listed below and the only thing added between the baseline run and the final run was the IM, TB, and the 123 MAF housing.
I will post the dyno graph later today as it is on my work computer or Mark if you have the copy I sent you , you can post it.
The increases are 30 rwhp and 20 rwtq with gains right across all rpm levels and it makes power up to 7800 rpm.
We will run it to 8000 once we install the high rpm pulse ring. All the dyno runs were done at the dealership on our Dynopack dyno and the tuning done by us with a SCT tuner.
The mods are AR 1 7/8 longtube headers , full 3 inch race exhaust with x pipe and a SCT tune . We used a temporary cold air intake for the dyno runs , we are making a permanent one this week .
Driveability seems fine but remember its a 302S so my street driving is limited to around the block trips.
The parts used are the CJ intake , CJ throttle body and the 123 mm maf housing
Tim
firestang70
SW Ohio Ninja
I wonder what the gains would be on a Coyote motor vs. Roadrunner. The power curve looks great there.
Rasmus
Nice gains. Thread title should be changed though.
Retro5.0
Nice gains for sure!! But I would really like to see what the gains would be like on a Coyote with the 6R80.
R1V3R5
5-Oh!
Huntsville, AL
At least the manifold is finally available. I'm waiting for more numbers, as I'm sure we will see coyotes, different tunes, etc.
BLK2012GT
Frisco, TX
But it will cost to 2k dollars for the manifold, TB and CAI so I don't know if that's worth it.
Clipboard
I understand cause I'm staying NA but 2k on top of everything else I've done is a lot but I'll probably end up getting it. Ugh
well after the boss IM cai and TB your not spending much more...so an extra 900 for 15+ rwhp and some torque is not too bad of a trade off.
price will drop sooner or later :)
BLK2012GT
Frisco, TX
I already got boss IM and accufab TB and steedas CAI.
kdanner
Austin
Those dyno curves sure are flaky as hell, especially the Boss intake one. Way too much up and down action going on there.
Less than that. My manifold and throttle body were under $1300 shipped from Tousley. That was the SCJ single blade throttle body, which isn't necessarily needed. A stock GT500 throttle body is significantly larger than the stock 80MM and would work well too
BLK2012GT
Frisco, TX
Cool thanks for the info.
Clipboard
i cant seem to find the Cobra jet manifold on tousley :yuck:
BLK2012GT
Frisco, TX
What CAI are you using with it?
