Caster Camber Plates
GOTTORQ
Connecticut
Well, after making the mistake of lowering my car on H&R supersports with brand new tires, and not spending the money the first time the proper equipment to adjust the camber, I just bought 4 new tires, and Koni yellow shocks, who makes a decent camber plate that gets the job done. What are you guys running.
tehdixie
the empire business
anyone using the UPR camber plates?
I did on my old 2v. It catostrophically failed at the weld and cost me a $600 hood.
Avoid their crap.
J&M makes quality plates at a good price.
tehdixie
the empire business
PS got some pics of your car with the super sports? I just bought a set off a member here
tehdixie
the empire business
Looks awesome! The hood and Eleanor style lights really work well together.
The stance is perfect, I'm glad jucostud decided to sell his Super sports and I was able to buy em!
hwm3
Cary, NC
I have the H&R race springs with the Konis and use the MM plates. They have a good range of adjustment. No complaints here.
Whiskey11
SCCA Autoscrosser #23 STU
Avoid their crap.
Sounds like Unauthorized Product Reproductions to me!
Maximum Motorsports, Ground Control and Vorshlag. They are all very capable ones. Ground control here, but attached to my coilovers. I like them, they will work out very nicely for what I need them for (more negative camber :p).
What was your Toe set to when you wore out your tires? If you didn't set that, THAT was your problem, not camber... How do I know? Because I ran at -1.7º of camber and zero toe all last year on a set of 200 treadwear Dunlop Star Specs and still had OUTSIDE tire wear. Camber kills tires with large amounts of toe going in either direction (in or out) but with neutral (zero) toe it is generally mild enough that a little more enthusiastic corner carving can solve a lot of problems.
PS: Has anyone else noticed a lot of "suspension" related posts with not much on corner carving? It seems to me the OP is interested in removing camber, which is counter productive for corner carving...
jayman33
Yep, my ground control coilovers get here tomorrow custom powdercoated ford blue, cant wait.
Whiskey11
Ahh, so they were YOURS in their picture with the Skippy Peanut Butter on Facebook! :D
Vorshlag-Fair
Official Site Vendor
Dallas, TX
As mentioned, we at Vorshlag make S197 camber-caster plates to fit anything.
We use a very strong spherical bearing, a very unique form of upper spring perch (with integral, sealed, double-row radial bearing), and a modular system to work with various strut stem profiles and spring perches.
Adjusting camber takes seconds per side - raise the wheel off the ground, loosen the four M8 top nuts at the strut tower, slide the wheel in or out, tighten, done.
See more here: http://www.vorshlag.com/product_info.php?cPath=141_142_179&products_id=274
Cheers,
speedfreak1000
2 sided tape expert
Springfield KY
i wish i had done alittle more research and ordered those just cause they are so badass looking. nothing wrong with my MM's in fact they are great but those Vorshags look like a work of art.
mfergel
Richmond, VA
I need to get some. My fear is that most shops might not know how to properly adjust them. I was thinking of J&M but wasn't sure how rough it would be compared to the non-adjustable GT500 strut mount.
phoenix335
MD
I went with the Vorshlag plates because of the high quality radial bearing. The MM use the factory radial bearing from your stock mount and GC plates do as well (At least that is what they told me when I called). Some folk say the Vorshlag are more noisy but they are not. I've had them in for two track days and a few autocross events and they are awesome. More expensive but worth it for quality and customer service you will get!
sholzer
Blacksburg, VA
Wish I could've afforded the Vorshlag plates, they really are a work of art. Just installed MM plates for the time being though, might upgrade later this summer or next winter for next season
