Big Top Gt
Thanks, I have the SPEC 3+ for the stock transmission already. Is the only difference the clutch being 26 spine? Kevin at PMP said I could reuse my pressure plate and flywheel so this cuts down on cost a lot.
I did exactly that when I went from a T45 to a T56 in my 98 Cobra.
One thing to keep in mind when you order is make sure you order the right size disc to match the pressure plate.
Like an idiot, I accidentally ended up with an 11" clutch disc and a 10.5" pressure plate. You can imagine my surprise when I tried to bolt it down.
I'm not sure if this is an 05 possibility, but I thought I'd throw that out there.
A
