Hey guys, new here to the forum, and to Mustangs, and I have a few questions I hope you can help with. I have a base '13 GT that I have built for track days. So far, no issues what so ever after several weekends at the track. However, I was at the track last weekend, and during my second to last session I started losing power and the check engine light flashed for a minute. I took it easy for a half of lap, and full power came back. I finished my session and ended up running my fastest laps of the weekend. After, I played it safe and took it home without running my last session. Has anyone had a limp mode issue with theirs, and do you know what caused it?
This scenario brings up the remainder of my questions.
1) I have purchased a Canton RR oil pan. Do any of you have any experience installing one? Are there any issues I will encounter that I should be aware of?
2) Car is a stripped down GT with only the necessities for track use, which means I have squat for gauges. I have no idea what the cause of the check engine light was, so I would like to get something that I can plug into the OBDII port, as the premiums come with all sorts of information they can toggle through, so mine should be able to spit this out to some sort of gauge/screen. Is there anything available that any of you have any experience with? Windshield or pod mount that can shows pressures and temps.
3) Does anyone have experience with the installation of the MMR cooling bybass kit?
I greatly appreciate any and all help guys, thank you.
Randy
Randy
