Official boss block build
Dillon Dollar
oklahoma
Okay the motor is coming out of Medussa next week and im replacing it with a frpp boss block
Bought the block last week from AM
Eagle stroker crank and rods
Diamond pistons 10-5 compression
Stainless steel rings
Arp 200 rod bolts
Stock valves
BBR stg 2 cams and heads
Paxton 2200 8 rib 2.85 pulley 10% od pulley @7000 rpm
Jpc return system on E85
I still need to buy billet oil pump gears, trick flow springs, and all the bearings
Some questions I have can I reuse my arp head stud kit that is on the current block?
And besides the special motor mounts is there anything else I will need? ?
I will update with pictures as the build progresses
Pictures:
More goodies
Headed to pro 1
Sent from my SPH-L900 using Tapatalk 2
Dillon Dollar
oklahoma
Good I was under the impression the boss block needed a special style of head studs.
That saves me 400 lol
Arp 200 rod bolts
Stock valves
You will need to plug one hole in the 3v timing cover and build up a little bit of material on the block. If you don't oil will weep out to the vee, make it's way to the oil pan filter, and travel back to the rear of the motor/front of bellhousing leaving a drip about once every 4 times you pull into the garage.
I've made a thread on it in the past.
Dillon Dollar
oklahoma
Alright ill see if I can find your thread about it. Thanks for the heads up
lethe
V4g!n@ #er
Everett, Wa
^Who did you get them from? I just ordered some from MMR. They were cheaper buying from them on ebay then through their website.
Dillon Dollar
oklahoma
I bought tsw gears they were pricey but everyone tells me to steer clear of mmr
JPO8GT
USA
Nice! 10.5:1 should be responsive Good luck.
I'm running a gt500 oil pump with TSS Billet gears (Triangle Speed Shop) out of Texas.
Fullboogie
King of the Ski - OG Jr.
Houston
Hey Dillon - if your car is named after the Greek snake-headed chick, it's spelled Medusa.
