Interceptor Gauge > Shift light?
Fullboogie
King of the Ski - OG Jr.
Houston
Yes, they can be used for a shift light. It's a three step process: (1) set the annunciator to "on"; (2) tell the gauge you want "rpm" as the trigger; and (3) set the rpm.
Once you learn the steps, it's easy to do. Unfortunately, every time you unplug the Interceptor from the OBD port (to load a new tune, for example), the annunciator gets turned off, and you have to go in and tell it to turn on.
bigstick
Tri-Cities, MI
Thanks! Worth giving it a try.
Ivan 5.0
Still learning...
NoVA
Honestly... your better off getting a shift light; the annunciator on the interceptor isn't all that bright.
drive_55_not
I had them set, the light was never bright enough for me for it to be useful.
I think it's bight enough, but you've really gotta' be looking for it.
In car video driving into an absolutely blinding setting sun. The lights are fairly bright but small.
http://www.youtube.com/watch?v=Gw742nFKnRw
I've also found it' can be slow to light at higher rpm's, Currently I've got mine set to 6800 and it's a crap shoot as to whether it'll light on the 1-2, 2-3 shifts since they come so fast ...
It does light on the 3-4 shift since it has more time to catch the rpm reading.
bigstick
Tri-Cities, MI
Yeah, and that's exactly what I was worried about...the data refresh not being quick enough. I'll probably be running into the same problem as you. I've got 4.10's and around 540rwhp.
