Tire Setup to Save Money: Boss 302, Please!
GHVA226
Hi guys,
So here is my dilemma: I will be driving my Boss on the track for the first time and opted for 18X9 inches wheels all around. I have a set of Pilot sport Cups which I bought for my past car and have barely used! I would like to use but don’t know how!
This is what I have:
(2) Michelin PS2 235-40R18 (80% tread left)
(2) Michelin PS2 265-40R18 (1,000 street miles on them)
My options are:
1. Mount these on the wheels and drive with a staggered set up, which grossly misses the specs of the car
2. Get rid of the 235’s and get a pair of 265’s, but I will not by PS2s again because they are too expensive.
I understand either way I go, it will be a compromise, but I am trying to identify the safer alternative, if there is one.
Please, guys shed some light
Thank you
All the best
Gus
kevinatfms
EX-ford tech(6 years)
MD
grab a set of take off 275/35-18 continental grand am scrubs. they work great and fit the 18x9. you can get them off ebay for around $250.
GHVA226
Sounds like a great option, but since I don't know this car really well, I would like to start with street tires to learn the limits first.
Anyway, you get the Continentals on Ebay?
kevinatfms
MD
yup, ive gotten a few sets. work great, just make sure to burn off the top layer when you get them.
zquez
Death Dealer
the sky
I'd run what you got staggered. The car comes set up staggered, just with wider tires than that. Street tires will wear out pretty fast at the track and before you know it you'll be able to buy what you really want.
No need to waste money if you don't have to.
Vorshlag-Fair
Official Site Vendor
Dallas, TX
Hmm.... the 265mm tire will fit the 18x9" fine, but that 235mm tire will be a S-T-R-E-T-C-H! And as I've seen with the 235mm tires that came on my 2013 GT stock, the grip levels will be POOR, to say the least. Like you said, I'd avoid racing the Continental slicks on your first track outing, of course (these are slightly harder Hoosier R6 tires with "Continental" branding). Slicks and R-compound tires can be tricky to drive on (less tire noise/warning, sharper break away, lower slip angle range) for new track folks or an all new car.
For the wheels you have and for your first track event, I'd recommend getting some lower cost 140-200 treadwear tires like the 265/40/18 Hankook RS-3 or similar. Great dual purpose track/street or autox/street tire. Makes lots of grip, wears well, they come in a LOT of sizes, and the price is right. Try searching tirerack.com for "Extreme Performance Summer" or "Ultimate Performance" whatever tires in 265/35/18 or 265/40/18. The taller 40 series tire works better on these S197 cars, for gearing purposes. I wouldn't go much wider than the 265mm tire on an 18x9" wheel... but I wouldn't spend much time on an 18x9" wheel, either. Looks like the best deal in that 265/40/18 size is the Bridgestone RE-11, which I am a HUGE fan of. It is a better tire than the RS-3 for track use.
265/40/18 Hankook RS-3 on an 18x9" wheel... better than a 235mm tire, but still not loads of grip
Now one thing I will note is - even the 265mm tire at both ends is less than ideal grip. I don't care what compound it is, this is a skinny tire, just asking for abuse on a 3500 pound/380 whp Mustang. But the 265mm tire is better than the 235 or 255mm junk these cars come with. :beerchug2:
Not a drift event, this was an autocross - using the 265mm Hankook RS-3
You can see from these two pictures I've posted above that the 265mm tire is a bit skinny on these big cars, and the RS-3 tire is not magic. It can be quickly overwhelmed with the weight and power of an S197 Boss 302 or GT. I have proven this too many times. ;) A better bet is a wider wheel and tire package, even with street tires...
I promise I'm not a drifter. These are 295/35/18 Nitto NT-05 tires on 18x10" wheels
The tire and wheel package above is an 18x10" wheel and 295/35/18 tire. This fits the car exceptionally well and adds 1.5" of tread to each corner. THIS should be the track "street tire" that more S197 Mustang owners go to. Why folks don't use a bigger tire than the skinny stock stuff... a total mystery to me. The best 285/35/18 tire out there is the BFG Rival, too.
Read my Mustang Build Thread (in my sig) for more about the extensive wheel and tire testing we have done on this chassis. I have a LOT of pictures and details in this gallery (231 pictures) and even more in my earlier Mustang build thread posts before I started posting this thread on S197forum, starting here.
Seriously... I swear I'm not a drifter. These are 315/30/18 Hoosier A6 tires on 18x12" wheels
Nowadays we've added about 50 whp over stock and have gone away from street tires to much wider R-compounds, more aero downforce, and better suspension. Even with a 315/30/18 Hoosier A6 gumball tires on 18x12" wheel at each corner... it still doesn't have enough grip. So now we're trying to go to a 335/30/18 front and 345/35/18 rear Hoosier. We will get the fenders cut and flared to clear these meats, finally...
Hoosier 315mm front/345mm rear. These rears would rub horribly when the suspension was loaded up
But even with the 345 Hoosier A6 on the back it was still easy to overpower the rears, in an autocross setting. Long story short - you can never have too much tire on an S197 5.0 Mustang.
Cheers,
Norm Peterson
corner barstool sitter
RIP - You will be missed
Terry - one thing that I am seeing is that the 265/40 tires of any interest here tend to have actual tread measurements that are essentially the same as 285-wide tires and frequently wider than the 275's. Is the structure of the 275's and 285's enough different to matter, is it the ability to work with wider wheels, or is it something else that I'm missing completely?
If it matters, I can't get very excited about mounting 285's on wheels that are only 10" wide. Particularly not after running the 18" GT500 front tire setup (255/45 on 18x9.5) all around.
Vorshlag-Fair
Dallas, TX
The section widths might be high on some 265mm tires, but the tread width should always be higher on a 285mm tire. Of course some tire companies "fudge" the numbers a bit, but generally they do that on all of their tires, and I've rarely seen them off by more than 10mm (there are a few notable "outliers" with extreme presidencies).
I am a bit confused about what you are saying.... do you think a 285mm tire is too narrow for a 10" wide wheel? I will assume that's what you meant, since the 18x9.5" wheel you talked about was running only a 255mm tire (that's a stretched fitment).
285/30/18 on 18x10" wheel on S197 Mustang
I've run 285/30/18 tires on a lot of 18x10" wheels on a lot of cars for a lot of years. This used to be the "go to" tire/wheel combo for all of my autocross and track cars... and a lot of other people's, too. Super common tire size in performance tire models. Unfortunately this tire is uber-short (sub-25" tall) for the S197 Mustang, and we've seen big performance bumps by going wider and wider and wider with these heavy cars.
The 18x10" wheel + 285/30/18 tire combo is very common in the BMW racing world
There are ranges of wheel widths that work with various tread/section widths. I tend to go wider on the wheel than most charts say is "ideal, but I'm still very comfortable with a 285mm tire on "only" a 10" wide wheel.
This 285/30/18 tire was a S-T-R-E-T-C-H on these 18x11" wheels, however
Generally, 285mm tires work well on a 10-11" wheel, and I suspect a 10.5" is ideal. This size is a bit of a squeeze a 9.5" or 9" wide wheel and look downright silly on an 8.5", but I've seen it done (wouldn't do it). Problem is - there ain't an 18x10.5" wheel made that fits the S197 chassis, even remotely well (the 18x10.5" Enkei some folks use on these cars stick out of the rear fenders by a mile). But the 18x11" wheel is a bit too wide for this tire width, as we've seen first hand (E30 above). That's a 11" wheel width more suited to a 295 or 305mm tire. For a 315mm tire I like to go 11-12" wide wheel, and I'm switching to all 12" wide wheels at all 4 corners on my own S197 (we run a 315 on an 11" front, 12" rear now).
The real key issue here is: wheel availability. The biggest "Easy" fitment wheel for the S197, one that fits both the front and back for easy tire rotation (same offset/no spacers/fits under the fenders) is the 18x10" wheel. We sell the D-Force and Forgestars in this size. Anything wider has compromises in some way (either sticks out past the fenders or has wildly differing offsets front to rear, or needs lots of camber to fit, or all of the above). Once you've settled on the fact that this is the widest wheel you can practically run "square" on an S197, your tire choices dwindle to this list:
  • 275/40/18
  • 285/35/18
  • 295/35/18
Those are the 3 tire widths that fit this wheel, and the most common sidewall ratios in those widths. I've run with all 3 of those tires on the 18x10" wheel on these cars, and each one has its pros and cons. The 295mm tire sometimes needs a 5mm spacer up front. The 285/35/18 only comes in a few brands. The 275/40/18 is the tallest of these 3 (and closest to stock height for speedo calibration) but is also the narrowest.
And like I've said 1000 times - these cars are freagin BIG and HEAVY, so run as much tire width as you can afford to. Don't piddle diddle on 8.5" or 9" wheels, go to 10's or don't bother. The only reason to use narrower wheels on these cars in motorsports is for rules limits (STX limits to 265mm tire/9" wide wheel, American Iron limits to 9.5" wide wheel/275mm tire, etc)
People ask us all the time, how we manage to put 2-7 seconds/lap on the American Iron track records, when we are running the same power-to-weight ratio? The answer is ADDED WHEEL AND TIRE WIDTH. This wins on big, heavy cars.
That's my two cents...
Norm Peterson
A few that I've looked at. Not all 265/40's have this much tread, but these 265/40's seem to have tread widths generally closer to 275/35's and 285/35's, and wider than 275/40's even though you'd tend to think it should be the other way around.
Michelin PSS
265/40-18 . . . 10.7" OA . . . 10.2" tread
275/35-18 . . . 10.9" OA . . . 10.0"
285/25-18 . . . 11.4" OA . . . 10.2"
Kumho Ecsta LE
275/35-18 . . . 10.9" OA . . . 10.1"
285/25-18 . . . 11.4" OA . . . 10.3"
RS-3
265/40-18 . . . 10.6" OA . . . 9.9" tread
275/35-18 . . . 10.9" OA . . . 10.2"
285/25-18 . . . 11.4" OA . . . 10.1"
No. A little too wide of a tire for 10" wheels (I'd mount 265/40's on 10's without thinking twice about anything other than mph in 4th gear).
Consider Ford's own OE 18" tire/wheel fitments . . . 235/50 on 18 x 8.5 and 255/45 on 18 x 9.5 . . . another 30mm of tire should be getting another full inch of wheel width, or 2" more wheel than 8.5" for being 50mm wider than the GT's 235's. Chevy's 1LE runs 285/35's on a 10"/11" wheel combination, with the 10" front wheel widths ultimately having to satisfy corporate understeer budget criteria that the rest of us are free to ignore.
But for the matter of availability, I could get really interested in 285/35's on 10.5"/11".
. . . since the 18x9.5" wheel you talked about was running only a 255mm tire (that's a stretched fitment).
Yes, relative to measuring width it is a mild stretch. But not an unreasonable one, as it is right on the upper "limit" of the tire industry's accepted range of wheel widths for that size.
I can't speak for any difference that stepping up to Hoosiers might make here, but every time I've made my wheels wider relative to whatever tire size, out to max recommended (and with 60-profile and taller tires occasionally half an inch past that), I've been happier with the new combination.
GHVA226
Thank you very much for all the great advice. At this point I really wish I had bought 10'' wheels instead of 9''. I have not even used the wheels, but the 30 day return policy has expired. Will probably try to sell these after the tires I have are gone (will run the 235/265 combo in the first event to see how it goes). Another alternative is to keep them as a winter set.
All the best
Gus
pcdrj
Bucks County, PA
First day on track? Run what you got. Unless you're driving studded snow tires I don't think tire selection will be an issue. Focus on the driver, not the car. At local open track days we run exercises in a Golf TDI with all season radials.
GHVA226
I am an intermediate driver, but have no experience at all with the car. Used to drive a 01 Boxster (214hp and 2300 lb)
