Gt500 fuel pump.
Goody05
Omaha NE
So now what? It's not like all the other pics. I'm just lost.
Goody05
Omaha NE
Ya thats what im going to do
Thanks for that link, it was the best I had seen.
Thanks for everones help.
Viperrmk
Miami
I had some what of the same problem. I ended up shrink wrapping each of the wires separate so only a little of the connector part was visible. then I was able to slide the female end in to the male connector side, and secured everything together. I didn't want to cut and splice the wires if I ever decided to go back.
* NOTE * mine is a 2010 so the color of my wires are going to be different.
In the first picture below it shows the old connector (the one you had to de pin) on the bottom. The top two wire connector is the one off the GT500 harness. The two wires you de pined from your old harness plug in to that one. and the old connector just sits there.
And here is a wiring diagram if it helps as well.
attachment.php
