ABS light and Brake light with skinnies?
KITT
Sell it!
JC TN
My ABS and Brake light came on first drive with my 17x4.5 skinnies and M&H racemaster. Has anyone else seen this or is something wrong. thanks for any input.
KrisR
Wyoming, MN
What size tires on front and rear? Enough difference in diameter could cause this.
05yellowgt
Dayton, OH
I've run 26" front runners and 28" rears without issue. Could you have bumped and dislodged a sensor while mounting the wheels?
Grabber Blue 5.0
I have Hoosier front runners that list at 26" but in fact are 25" just like all the other 17" front radials out there with a 28" rear. No ABS light.
KITT
Sell it!
JC TN
My fronts are the M&H 185/55/17 and they measure 24.5 inches tall. Just so other will know.... I put the stock tires back on and the lights went out. Thanks for the replys. My car is an 08 if that helps anyone else. Really dont understand why this affects it but I only run them at the track so no big deal. If anyone knows how to solve this I am still interested. thanks again
tmcolegr
It's All About the Build
Central, FL
I an running that same tire and it measure 25.8" tall
86GT351
Sunny South Florida
Remember that your ABS signal is based on wheel rpm. If you have a 24.5 inch tire on the car the rotation is off far enough from the rears that the computer recognizes an issue!
KITT
Sell it!
JC TN
thanks for the info. I assume theres no way to adjust this in the tune?
05moneypit
Grove City PA.
You could try cheating it a little by changing the revs per mile in the tune...more revs smaller tire. Will through off your speedo and may still cause abs faults, might worth a try though.
On the tire pressure. I run 45psi at the track, gives a little less roll out and less rolling resistance. I know guys that run 55psi in the fronts but I ain't that brave.
Lee
86GT351
Sunny South Florida
Lee
Correct. There are small ways to help but with a major tire difference you just have to deal with it!
KITT
Sell it!
JC TN
update: The lights came on again after the stock wheels were on and the car got warm. Checked over the system very well and found a loose ground at the drivers headlight by the ABS module. Fixed the problem. Just a heads up for anyone else. thanks
