lethe
V4g!n@ #er
DELETE
Please delete.
Please delete.
This whole kit is still brand new. It was mocked up on my car for less then 24 hours before i decided to go a different route for a power adder. Here's the list of everything:
* On3 hot and cold side piping
* Comp 6765 billet wheel, journal bearing turbo ( Compressor housing tapped for pressure source
* Comp Turbo blanket
* All clamps/couplers/fittings/bolts etc that come with the kit
*Trans dapt oil filter relocation w/ 3 motorcraft F1A filters
* AEM filter
* On3 BOV and Wastegate+springs ( comes with metal gaskets for the Wastegate)
* HPX pmas maf
* S&H Breathers ( not pictured)
* BNIB turbosmart MBC ( not pictured)
The Maf flange was welded on backwards (oops) So the ears of the maf have been modified so the maf could be mounted facing the right direction. $2900 shipped.
Filter relocation and all other hardware/hoses
Hotside
Cold side/ upper radiator crossover
drool...why cant i have my turbo fund now instead of maybe next year....
glws
Hey man where are you located?
what power level is this kit capable of?
Is this a s&h kit?
I wounder if the turbo are the same and brand new nothing been used?
This isnt our kit. It is missing hightemp coating 60lbs injectors upgraded wire kit and our 405 fuel pump kit. Other then that it is our kit with some extras.
How much ground clearance do you lose with something like this? 2in?
^ This
We can provide the injectors/wire uprgade/fuel pump upgrade easily enough so don't let that keep people from buying this kit!![]()
Damn, I wish I wasn't such a pussy.
