Wes06
- Joined
- Jan 21, 2012
- Posts
- 5,384
- Reaction score
- 64
no, its to lower the compression resistance of the material, since there is less material there itll compress easierIs that hole in the middle for a bolt?
I have K springs and checked mine yesterday. Found out my car was riding on the bumpstops at ride height. I promptly cut them in half. Rides 100x better now.
Sweet! Thanks man! I have that for sure haha!A razor knife worked great.
So thats my issue...
This whole time since I installed the Steeda Sport springs, I thought I got the wrong springs because they seem to be too "soft". I could feel I was bottoming out and hitting the bump stops. I could feel the rear compress, then it a wall...basically once it hit that wall, it would eject me from my seat.
Now, the only issue I have with cutting my bump stops is that it will increase the suspension travel and I have passenger side over axle exhaust tube clearance issues.
I will be definitely hitting the pipes now!!! sigh
Why can't I find a decent exhaust shop. sigh
Thanks for this thread!! I was thinking these Sport springs where not a good choice.
I have steeda sports and cut my stops along time ago. During hard cornering auto xing I don't nearly get enough travel to hit the OA pipes. How close are yours to the axle?
Sent from iPhone
Well, its due to a local shop that installed a couple of resonators and they somehow fudged up my passenger OA pipe because at stock height bump stop contact, my axle tube contacts the pipe.
Not to mention, my Watts Link frame contacts the pipe. I have the pipe wrapped to prevent it come rattling and hitting the frame.
Thus my frustration with local shops and their quality of work...lack of attention to detail. The driver side is fine, plenty of clearance.
I thought about ordering a set of 2011 OA pipes from Lethal that are supposed to have a deeper arch over the pipes...but not sure if they would work on s 2005-2009 model.
LMR sells pypes over axle pipes for like $150. Alternatively, the pipes are about that much a piece from the dealer. You could get a new oem one for the passenger only.
I solved any over axle pipe issues by running dumps, and saved weight.
Man up and just do it!
The OEM over axle pipes have flat-spots shaped into them.
Gerald, consider the Roush Extreme exhaust - built-in resonators, no flat spots, and it fits perfectly. The only issue is you need custom exit pipes made for your S3 rear fascia.
I have a full 3" MBRP system with mufflers that I make you a smoking deal on.
