Grabber
Coyote Snob Member
Hey guys,
I did some searching and only came across a few threads here about clutches, and need some specifics.
I've ready that Exedy Mach clutches are the way to go on 05+ Cars due to the very few issues and reliability.
Currently, I am looking at the following.
http://www.americanmuscle.com/exedy-stage2-clutch-0510gt.html
With the following Flywheel
http://www.americanmuscle.com/exedy-race-flywheel-9604-6bolt.html
Also considering upgrading the Slave while I replace the Clutch/Flywheel
http://www.americanmuscle.com/exedy-tob-slavecylinder-0513.html
I'm not very technical and am always scared of ordering transmission components as I am not sure as to what I need and if it will truly fit my application.
Do the Clutch and Flywheel above work on a 5 Speed manual 05 GT, and do you suggest getting a better slave cylinder/throwout bearing?
I greatly appreciate any help here.
-Chris
-Chris
