Clutch Bleeding / other?
Dank420
Pennsylvania
I recently replaced a spec stage 1 clutch and flywheel kit with the same exact kit. I also installed a new slave cyl / throwout bearing with the same part. The pedal used to be a monster to push down and felt great. I've been trying to bleed it all day, pumping with driver side up, using a vac pump, bleeding from aftermarket elbow.
Here is the question: I am getting full disengagement of the clutch when I push all the way down, but my engagement point is crazy high now. The pedal also feels mushy now instead of firm. What it do?
