"Tick tick" sound from clutch at takeoff
ghunt81
New parts on old junk!
Clarksburg, WV
So about 5 years ago I did a clutch job on my car (new flywheel, new crank bearing, Luk clutch kit with ARP bolts, new slave cylinder, braided clutch line) and also installed a DSS aluminum driveshaft with red loctite on all the bolts.
In the past couple years I have noticed a "tick" sound from the clutch when I start from a dead stop- sometimes once, sometimes twice.
Any idea what could be making that noise?
cavero
NoVA
Did you shim the new slave cylinder? I wonder if it has some room to move around?
brasil
Germany
A bone stock clutch kit ( like LUK , Sachs , Valeo ) don‘t need any shims .
What is about the sheet metal between the flywhell and the engine block ?
ghunt81
Clarksburg, WV
I have exhaust leaks but that is definitely not what this is.
I had a rattle in the engine shield when I first got the car but I fixed that a long time ago.
I think I did use one shim but I don't remember. I had posted a thread on here about it and got all the measurements.
MrBhp
My dodge truck had that happen some time ago. The pressure plate was coming apart. I ran it till it let go.
MrBhp
I meant to say friction plate. The retainers that held the hub springs in place were plastic. I didn't use that clutch brand again.
WJBertrand
U-joints will often click when they start to fail. Could that be what you’re hearing?
