nitorus & 4.10s?
ScootDawg
Lake Charles La
i want to do a 100 shot but don't know if i should upgrade to 4.10s or leave my 3.73
2nd question:Was thinking about the Zex black out kit thoughts?
3rd Question: Plate or no plate?
4th Question: i'm plan on using a window switch, should i spray in first with the 4.10s/3.73, or wait till second gear? (note: first time nitrous user here)
any info would be greatly appreciated
DVEST8R
well im auto with 3.73's on a 26 in et street, on a 150 shot single nozzle, spray from the start. don't care for the zex stuff. if u have a manual trans a window switch is a must. with suspension and a bias ply tire I say spray it from home !!!!!.my times in sig
ScootDawg
Lake Charles La
well im auto with 3.73's on a 26 in et street, on a 150 shot single nozzle, spray from the start. don't care for the zex stuff. if u have a manual trans a window switch is a must. times in sig
Thanks are u spraying 150 shot on stock internals?
what N20 brand do u recommend?
ScootDawg
Lake Charles La
What tire are you going to be running? You running a manual or auto?
got a stick car
right now have 305 40 18 555r (i know shitty for the track) but plan on getting 15X10 race stars, and if i go 4.10s will be planning on a 28" tall tire most likely et street
DVEST8R
yes 150 on stock internals....I recommend nitrous outlet. they are vendors on here. I think you can get it done on the 3.73/26x11.5x15 et streets
ScootDawg
Lake Charles La
Whats ur suspension set up is ur car lowered? right now i'm lowered on eibach springs and thats it. I was looking toward some of the bmr packages, but i don't want to be strictly drag. i want to be able to auto x and some track days. turn the spray on when i go play with friends at the drag strip
ScootDawg
Lake Charles La
another question? i was planning on running a wide band and nitrous pressure gauge. Is a fuel pressure gauge need also? or is that over kill
DVEST8R
stock springs/shocks, bmr uppers, lowers,poly diff bushing,che brace
DVEST8R
would you happen to know your pinion angle? im having wheel hop issues and i have the bmr k member been told the che brace won't work with that
-1.75 *on my car....if u have aftermarket lca's and uca u want to see -2-3* with poly stuff seeing as how u have a manual. with hop on ur car , since ur lowered, u need lca relo brackets to correct susp. geometry
07 procharger
Addicted to modding
Red Deer Alberta
Im sprayin a 200 shot thru a nitrous outlet custom direct port set up with 4:10's
I started out not spraying in first, I went to the track on Friday and after I got comfortable I started hitting it in first. Traction is an issue for sure, I'm on M&H Racemasters 275/45/18 with Full BMR arms and QA1 double adj shocks
Pinion is at -2
I run a window switch and a pressure gauge as well as a wideband. I have FPSS inline so no need for a fuel pressure switch in the cabin. Know what I look at during my runs? The end of the track..I honestly don't look at any of my gauges.
I'm not lowered, and I am currently looking at moving to a slick as my 60 foot times are sucking.
best run on Friday was 11.74 at 122 with a 1.90 60. (3000 ft elevation)
To answer your other question, leave the 3:73's in for now and hit it in 2nd to start...go from there. my 2cents
DVEST8R
I assume u are not on a stock long block 07 procharger??
phattyfat
Connecticut
DVEST8R and 07 Procharger what does your fuel system consist of? I was running a 150 single nozzle with stock set up and a boost a pump and leaned out #5 and melted a plug now I'm trying to figure out why.
OP I have 410's launch and spray out of the hole with old mt et streets 26x11.5 and don't run out of gear at the strip.
ScootDawg
Lake Charles La
Thanks for your info i forgot to ask about fuel i have a gt500 pump which i should be good there but what about injectors? Stock or i have some 39lb injectors
07 procharger
Addicted to modding
Red Deer Alberta
I run the FRPP gt500 pump kit with 39 pound cobra injectors. I was spraying a 150 fogger on this set up.
Now I run a stand alone fuel system for my 200 direct port set up. So its all overkill now.
