psfracer
billy badass
Yes that could be piston slap in which case the noise will lessen as the engine comes to operating temperature. Have you had it running long enough for the engine to reach operating temp?
that is not a piston slap noise...
I have a new set coming and will be priming them before install... showed the video to my engine builder and he replied welcome to 2618 piston problems... he said that piston slap was his guess without actually listening to it in person...he said the motor was set up on the looser side
wrist pin?
Are they floating with side keepers or pressed?
It's a noise I wouldn't ignore. Can you isolate it to a cylinder by pulling the COP (ignition load).
I did use copper rtv on the exhaust manifoldsYou used rtv on the exhaust manifold gaskets? Did you clean/and how the mating surface for the exhaust manifold gaskets?
