The electronic testers are junk. Only way to properly check is in car with a good machine. More important that voltage is amperage. Under load there is more amperage draw. If the draw is too large, it can cause the diode to go nuts! I would suggest replacing it now before you get stranded like you think.
That's what I was thinking, testing a lot of electronics at low load show nothing. I notice it's upon hard acceleration or slowing down from a quick 3rd gear pull on the highway.
My charge light use to come on like that. Set my Aeroforce to watch voltage. Voltage would be 14.x and then suddenly drop to 12 or less and light would come on. Sometimes it was 10 seconds, then it was 3 minutes. Voltage would go up to 14.x again and all would be fine. This went on for weeks. First 3 times the light came on it was every other week or two.
Finally bought a rebuilt from Advance Auto (stamped Motorcraft just like stock one) and it has been fine since- over a year. plus Advance has some great online coupons (big savings) to use and you can pick it up in the store.
Yea I will bet that is what is happening in that few seconds the alternator just drops off and picks back up... now i'm still conflicted on what alternator to buy!
edit: autozone is all duralast... any good?
Anybody have part number for the updated alternator? (heard there was a change after 05.)
