obxdude018
I have tried the clutch switch by hand a few times with a no go, like I said all I have to do is smack the shit out of the BEC and it will then crank.
You need to test voltage at 1 place first, and go from there: pin D12 of BEC connector C1035B, of PCM pin #2 of the middle connector (the LG-YE wire).
- When the key is on (not starting), there should be 12v at that wire.
if there is no voltage here, trace back through the relay to the BEC to fuse F21.
- Cranking, the voltage should go to 0 volts (if the pcm is internally-allowing the start to occur). if voltage stays at 12v or near it, the pcm is not energizing the relay coil and it wont start. If the voltage is going to 0 or close to it, the relay should be energizing and the issue is on the F4 side of the circuit.
I diagnosed this when figuring out a pats issue after a swap project.
Key-on verifies you're getting voltage to the pcm. You'll need to turn the key to see what happens in the cranking position, if it stays at 12v or drops.
You can test it at the bec connector, wherever you're reading the 12v now. It would not be near the firewall, as that circuit runs from the bec direct to the pcm down by them both.
Verify clutch pedal operation. check pin 33 at the pcm's middle connector, the lb-ye wire. With clutch pressed, it should go to 0 volts; released it'll go back up to 5 or 12 volts.
You can do this with just the key on, not cranking.
Cool; that's progress. The pcm is not allowing it to start. You got voltage there through the relay coil; that's good so far.
On the clutch pedal, there are 2 separate switches. One is for starter control (shown in the link to the wiring diagram you posted), the other is to disable cruise control (not applicable to starting), and can be seen here: http://iihs.net/fsm/?dir=40&viewfile=Speed Control.pdf
Are you using a manual pcm and manual engine/trans wiring harness? Doesn't really matter at this point, since you're able to start it with your bypass. Just asking because this has more to do with your wiring color comments; on an auto harness for starter enable, the wires are wht/pnk or red/vio, different for different year models.
For the clutch connector/wires under the dash, that shouldn't matter.
