Race Stars complete setup
crownaviation
http://www.tudyno.com/
Broke dafuk down
SOLD!Always wanted a set of Bogarts so going to buy some. That means I have my set for sale.
These are the DIRECT DRILLED version as I refused to run the uni-lug.
This set is about a year old this month. Tires have about 15 passes on them and maybe 20 street miles (live close to track). Never left on the car for more than a few hours and Drag radials were properly broken in. Air always let out after using them and properly stored.
Fronts are 15x3.75 with Kuhmo P165/80/15 skinnies (super light). The fronts DO clear the stock rotors/calipers with no modifications. Only thing necessary is the balancing weights have to go on the outside of the wheel for them to clear.
Rears are 15x10 with Hoosier 27x11.5x15 Quick Time Pro NOT A CONVENTIONAL STREET/STEEL RADIAL.. SHOULD BE USED ON TRACK ONLY. Rears have been studded so they do not slip. I do not run tubes and they never leaked. Rears also have metal valve stems (NHRA requirement).
These are in good condition with just a few blemishies from installation/removal/storage. Most scratches you really have to look for and will likely polish out (have not tried yet as was not a big enough a deal to me). One rear tipped over when removed and marked up the rim a little. THERE ARE NO BENDS or performance issues with these. I did not clean them yet and will get better pics once I do.. they clean up real nice!
I will include all the Hubcentric rings and McGard lugs/washers. I DO NOT RECOMMEND USING THE GARBAGE RACE STAR LUGS!!! The McGards are silly expensive but a must. I have all 20 McGard lugs and washers included with these.
Prefer local pickup but will ship at your expense or drive 100 miles from 67101 (Wichita KS area) to meet you.
$800 plus paypal and shipping These suckers are expensive once you start buying tires, lugs, mount/balance etc.. Chance to own them CHEAP
Best way to reach me: [email protected]
Fronts
Rears
NOT CURB RASH.. This is the area I described in the listing. Damn thing fell over when I was preparing to mount them for the track. Cosmetic.
crownaviation
Broke dafuk down
i have to say the rear tires don't look like radials, they look like bias ply tires
Yes.. good catch on that. I did mention "radials" on the back. Hoosier Quick time pro is a "drag radial class" tire (not a "slick") but they do not have steel cord sidewalls. They have Nylon based sidewall for better wrinkle/traction. They really should not be used for Highway use.. especially extended highway use. I live 3 or 4 miles from the track and all street driving to/from the track and that is fine. I would not use these on the highway by any means..
