blacks197
Mark is running a 3 link with every component available for it.
2013 a6 with paxton
1.54 60's, best was a 1.486
- Shocks - lakewood 90/10 front/lakewood 50/50 rear
- Rear springs - cobra jet spring all four corners
- Lower control arms - bmr fixed, with relo brackets on top hole
- Upper control arm - stock
- posi - stock
- Pan hard bar - steeda adjustable
- Pan hard bar support brace - stock
- Gear size - 3.15
- Brand/ tire size - mt et drag 28/10.5/15 stiff wall
- Convertor circle d 3c
- Anti roll bar or which rear sway bar - stock
car doesnt hit real hard at all, and almost feels like its slipping a little out of the hole. what would be the next upgrade to help drop the 60's
18 psi hot
I just read through this thread again looking for UCA info and tips. I love this thread! So much great info in here! So far, my front running options are BMR and Racecraft. Two different worlds, but lots of folks seems to love the BMR stuff and there are a lot of cars hauling ass with Racecraft parts.
18 psi hot
i would drop some air out of the tires
Tell me about it. 1.4s and "car doesn't hit hard at all". haha. I am obviously waaaayyyyy out of their league.Damn mofo's complaining about 1.4's making my 60's look sad![]()
update from my previous post:
- Shocks - strange single adjustable
- Rear springs - cobra jet (m-5300-q)
- Struts - strange single adjustable
- Front springs - cobra jet (m-5300-q)
- Lower control arms - metco
- Relocation brackets - BMR
- Upper control arm - metco (with metco UCA mount)
- posi/diff - eaton truetrac
- Pan hard bar - competition engineering adjustable
- Pan hard bar support brace - competition engineering
- Gear size - frpp 4.10
- Brand/tire size rear - M/T ET street (bias) 26X11.50-17LT on OEM wheel
- Brand/tire size front - M/T ET front 28" on 15" weld rts
- Clutch or which converter at what stall? - OEM clutch
- Anti roll bar or which rear sway bar - OEM sway bar (no arb)
pinion angle set to -2.5 deg
LCA set to middle hole on BMR relocation brackets
UCA set to uppermost hole on UCA mount
front tires @ 40psi
rear tires @ 15psi cold
front struts at full loose
rear shocks at +3 clicks from full loose
4500 rpm launch
12.517 @ 108.12, 1.65 60'.... (slip)
approx 3600 lbs with driver (1/4 tank of gas, full interior and gutted trunk). Temps were mid 60's, DA hovered around 700 ft; N/A 302 rwhp.
3600 pounds w/driver? Are you sure about that?
Jeeze, I am at 4020 w/driver and have all tube everything.
