ford20
It's his brother's Boss IIRC. Although I will be doing the same thing a little bit later on as well.
Cam, who's Mustang were you in? That's not the Bullitt or the black Shelby.
I guess that is true as I sometimes forget you guys store your Mustangs.
Which is a good idea and if I lived up there I would be doing the same.
Terry
Sweet! What gauge cluster is that? FL 5.0?
Just ordered a set of CHE lca relocation brackets to replace the BMR ones I have since I also ordered a CHE axle brace
Why the switch? Will the CHE axle brace only work with the CHE relo's?
Yeah the Che brace doesn't work with bmr relo's
Huh..glad I had the axle's welded vice the brace!
Cam,Brothers/Dads LS. I've been keeping it in my garage for a little over two months but drive it regularly.
I have been through your area multiple times and the salt/chemicals are so thick it is like a White FogYeah, too much salt on the roads. The salt in these areas destroys these cars. I drove my Bullitt daily for 3 years and the only reason it stayed in decent condition was because I constantly rinsed the under carriage and car off, and had a ton of wax on it.
