06Torch
After 80K miles on the OEM struts it was time for replacements. I bought some used Saleen N2s from a member here. The plan was to use them with a pair of Bullitt springs I've had for a couple years now. From what I've read, they lower the car 3/4" with the ride being slightly firmer than stock.
The install went better than expected with no issues. A far cry from the Fox installs of yesteryear to be sure... Anyway, both the N2 struts and OEM strut were identical in terms of overall height, shaft extension, mounting positions, etc... I removed the old struts, swapped out the top rubbber isolators, assembled the N2s along with the Bullitt springs. The N2 seller threw in some camber bolts so I used those.
I lowered the car and wha-la, the damn thing sat 2 inches heigher!
WTF??? The front sits higher than the rear now. To my amazement, the alignment guy said the car's camber was dead on. He said he would have never guessed someone installed "new" parts. The car did have a slight toe-in on the passenger's side.
So, what the Hell happened? Where did I go wrong? Are N2s supposed to be used with lowering springs? Or, can they be used with OEM springs??
Thanks all,
Gerardo
WTF??? The front sits higher than the rear now. To my amazement, the alignment guy said the car's camber was dead on. He said he would have never guessed someone installed "new" parts. The car did have a slight toe-in on the passenger's side.So, what the Hell happened? Where did I go wrong? Are N2s supposed to be used with lowering springs? Or, can they be used with OEM springs??
Thanks all,
Gerardo
