OK, I'm trying to learn about cams and comparing the specs a pattern is definitely showing through.
Comp Cams 127450- 229 240 @ 0.050" 0.535 0.555 on a 113 LSA
Livernois custom recommendation- [email protected]" .535" .550" on a 114.5 LSA
Livernois stage 3 blower cams- 229/236 @ .050", lift is .535/.550, and the lsa is 113
FRPP Hot Rod cams- 221/240 degrees @ 0.050", lift is .472", lsa is 110 degrees
The two off-the-shelf blower cams have similar specs and the custom recommendation from Livernois is at the opposite end of the spectrum from what I currently have. I'm thinking the 114.5 lsa would be far too much and an overreaction from where I'm at now. All the aftermarket cams listed have much more lift and require upgraded springs but my heads already have the upgraded springs. I also have limiters installed in the phasers so I should be good to go with whatever I choose.
I'm thinking the 127450 and Livernois Stage 3 are close enough that they can be considered interchangeable and I can get whichever is priced better. Both have a 113 lsa which will hopefully improve my idle characteristics over the Hot Rods without killing low end torque (as described on this page- http://www.compcams.com/Technical/FAQ/LSAproperties.asp ). I also think the 114.5 lsa would be going too far in the opposite direction so that one can be crossed off the list.
