The instructions I got with my RXT and McLeod flywheel said not to remove the floater plate.
The flywheel and clutch were ordered at the same time and shipped at the same time in separate boxes.
I'll report back what hte instructions say when I get it. Lee said he removes the floater plate.
Did you have your clutch and flywheel setup by McLeod? If you bought it from a vendor, or course it will come in separate boxes. When you get it setup by McLeod it comes in one box and parts are marked.
Update:
Interesting, just read McLeod's instructions online and they are totally different from what McLeod has told me in the past. But then again, my flywheel and clutch have been pre-set by McLeod.
Will be interesting to hear back from Dimora.
I'm curious as well to see what the instructions say and if they conflict with what Lee said over the phone.
So you had it custom machined for your flywheel? Why? As it comes out of the box the floater is set to a tolerance that will allow it to work with any flywheel that is in spec. That's why they say not to mess with the floater, it's shimmed to work with any Ford spec flywheel, including McLeod.
Even when I had a McLeod flywheel and rst there were no issues with it on the first motor or the second one and I surely did remove the adapter ring from the flywheel.
You are now stuck with sending the whole assembly back every time you need a clutch? FYI the floater is what both clutches contact. It seperates them and acts as a friction surface for them. The floater is what allows a twin disc clutch to work. That's why it has to be precisely located between the clutches.
No, my flywheel never got machined. When I say McLeod speced/setup my clutch I am referring to them checking all the tolerances and bolting everything up to make sure its perfect.
I send my clutch to McLeod because its part of their customer warranty to check over the clutch after every removal; its free.
The instructions Lee has always given me (personally) is to not remove the gold ring or I would undo their critical installation.
Bruce, are you sure the floating ring is shimmed? I don't think it is as I have R&Red it several times and there are no shims...its a simple bolt-on.
You were lucky with your RST as most of us ended up with a bad gold ring that caused issues; according to McLeod.
Alright - McLeod is done with my clutch and flywheel setup.
Quick review: I sent them Skwerl's slightly used RST and asked them to convert it to an RXT and mate it to a brand new McLeod 6 bolt lightened steel flywheel.
Total for upgrade, setup and shipping: $550.00. I bought the flywheel separately from JPC racing, so add another $379.
With the upgrade, I got a new pressure plate and floater as part of that $550.
I spoke with Lee, told him the whole story about problems with my RST and TR3650 with factory GT flywheel, and he told me that the problem was
improper installation. Hmmm. He said folks that follow the directions and pictures never have an issue. I did not install it myself, so I cannot confirm or deny proper installation or not, but I did use a grat mechanic who I trust and I gave him explicit instructions to follow the instructions! Perhaps the autopsy upon removal will shed some light. (Car is still intact at this moment with my other RST and stock GT flywheel on a TR3650). I am using this new RXT converted setup with Skwerl's T56 Magnum XL I bought.
I asked Lee specifically about what to unbolt or not unbolt - and about shims. He said it did not matter - as long as I follow the directions. He said install instructions (with pictures) are included in the return box.
Lee said that he could Blue Lok-Tite the gold ring to the flywheel for me and torque to spec, or I could do it myself. He said that there are no shims used on the gold ring. More on shims in a second.
Lee said that unbolting the floater ring is easiest for installation (Leave gold ring mounted). So...remove the pressure plate and floater ring, install flywheel, install inner disc, install floater, install top disc and pressure plate.
I asked if he could e-mail me the instructions he was referring to - and he said the proper instructions will be in the box. Good enough.
I asked about what is shimmed. He said that
NO SHIMS should be used on this clutch at all. He said it leaves the factory within spec
with no shims.
I asked for clarification on whether shims are used on the gold mount ring or the floater, and again, he said
no shims are to be used anywhere. I probably should have asked if that held true for both RST and RXT but I did not.
He said that people sometimes use shims to get clearances after they warp their floater ring -
which is wrong to do. If the floater is warped, it should be replaced.
So...there you have it. When I get it back, I'll carefully inspect it all and follow the instructions precisely (or make sure my installer does). I'll probably pull one gold ring bolt and make sure they used Blue Lok-Tite. If confirmed, I'll re-Lok-Tite the bolt and torque it to spec. I'll tell the installer (if it is not me) to follow the directions precisely. Of course I am assuming the instructions will precisely match what Lee just told me over the phone. If not...I'll be calling him back to ask about any differences.
I really want to install it myself to make sure it is done right, but I don't know if I'll have time. Work is brutal right now. I may get access to a lift on a Sunday through my neighbor and get to do it myself. I really don't want to lie on my back again for this.
I'll post up the instructions that come in the box when I get it and keep this thread updated with break-in and my end results. I'll be
if this clutch has to come out again.
Shane
