Is the DSS aluminum driveshaft worth putting on since I'm getting FRPP 3.73 ring/pinion gears installed ? I plan on putting a ProCharger on next spring (2015), but for now just the new gears and J & M lower/adjustable upper control arm (with heavy duty bracket). I am assuming that I'll need a new clutch/pressure plate next year with the ProCharger, and realize that I can wait till then for the aluminum shaft. Will I notice anything with the aluminum ds ? The car only has a JLT CAI, BBK 62mm TB, Basanni axle back ss exhaust, and a 93 octane Bama tune.Thanks !
