Agent 47 Brake Ducts
mitch
HPDE Instructor
Ft. Lauderdale
Excellent.
3.73 is probably what I'll do.
I'm running Sebring in 6 weeks, but will likely still have the 4.10's in.
I had a T2R in my other car, and it was terrific. 7 years of tracking with it, and not a single issue.
Pretty sure I'm going to make my own cooling kit, but I will probably buy the front ducts from Agent 47. The rest I can do myself.
Will def have some pics and vids from Sebring.
2Fass240us
Turning the OE brake shield into a cooling piece is pretty easy. I didn't have time to make one, so I went A47.
mitch
HPDE Instructor
Ft. Lauderdale
Oh... didnt even think of using the brake shield.. My buddy's a welder, he has made some from scratch.. I feel dumb now. I'll check that out. I havent even had this car on jack stands yet.
Shotokan1509
CT
Bringing this thread back to life!
I just bought an 07 GT/CS. The Agent 47 kit looks like it will work well with my front bumper. Can anyone confirm this??
OR, is there a better kit for the GT/CS bumper??
TIA,
I have to admit I still havent connected them, but they are high quality pieces that should gather air very well
2Fass240us
Take it from my experience: it's 10x easier to put the 3" hose on with the inlets OFF the car. Go ahead and use 3" hose clamps while you're at it...you don't want that somebeach coming off while on track like mine did.
I am Legend
McKinney TX
If you don't mind playing with fiberglass (it's easy), then it shouldn't be hard at all to make the stock grille work. Some time ago I did a write up on a DIY brake duct system ($90 all in). I can find the link to that later if you're interested. Here's the super short version.
1. Modify the OEM grille (easy, be patient, go slow):
If you're doing it right, this is what you're looking for:
2. You should be left with this:
3. Moving on to the backside, you get to play with flower foam! (This stuff shapes super easy, dusty, but you can practically just look at it and it will conform to the shape of your willing.)
Note that this is a very rough form still. You should smooth it out more before glassing it up. If you've never tried this before, relax, as it is hard to "F" this up. The best way I've found is to coat the foam buck in resin, sand it smooth, and then wax it 2-3 times (acts as a release agent). Then do your wet lay up, and after an hour or so, it should be relatively easy to pop the buck out of the duct. If you don't do this, you're still good. You'll just have to cut the foam out of the dried duct. It's messy, but the foam offers little resistance; it stands no chance, it'll just be messier. As I said, you really can't mess this up.
4. Here's the final version from the back (Note, it would've been easier to just glass the whole thing using the grille itself as the base, laying the fabric over both foam and grille. Of course, you'd want to mask off the grille so that it wasn't a permanent attachment and you can pull the duct off of it.)
And from the front:
Easy as pie. Just one $15 box of standard automotive fiberglass kit should do it (I used epoxy resin, but it's not necessary for this application).
Best,
-j
This was a great write up! I followed this method to make my ducts. I like the way they turned out, and was a fun weekend project. The hardest part of the whole deal was finding a supplier for the foam lol
mitch
HPDE Instructor
Ft. Lauderdale
Funny... I sell Foam for a living too.. Expanded Polystyrene, not that stuff.
But it will work just as well.
On a similar note, CDC (classic design concepts) makes a brake duct cooling kit to mate with their front chin spoiler. It consists of 2 x lengths of 3" OD high temp,dual wall silicone hosing....and two new dust shields + misc hardware. The dust shields have the angled short tube welded on to accept the hoses. http://shop.classicdesignconcepts.com/mustang-chin-spoiler-brake-duct-kit-2010-12
This only is available for 10-12 cars...that use the CDC front chin spoiler. They use a slick method to go under the oem windshield wiper fluid bottle. The brake cooling kit is not available for the 05-09 cars.
jbido
Ive seen it on a buddys car. Its pretty bada**
Mine uses 2.5" silicone hoses...smooth on the inside and corrugated on the outside. Mine was installed back in aprx Jan 2013. They appear to now be using 3" hoses. My wheels won't clear the 14" rotors...so am using 12.4" powerslot front rotor's. The CDC dust shields are made for 14" rotors....but work just fine with 12.4" rotors. You just end up with slightly bigger dust shields.
Air is free..so why not use it ?
2Fass240us
This doesn't seem that conducive to flow, but I can see the challenge of trying to get around the wiper reservoir.
