The resistor wire on the front of the motor is a key on power source. It's pretty easy to find key on power with a multimeter and pin or needle. I've used the maf power before without issue.
Cutting into the harness isn't a big deal at all. If you screw up you can splice the wires back together. It's not like they are shielded or susceptible to bleed over.
