Anyone install an AFCO HE?
NastyStang113
Made in U.S.A.
Central Florida
I want to know how the piping is ran to and from the heat exchanger. It's the one from the GT500 and it's going on a 4.6 with a Roush TVS. Thanks in advance.
MLC40
Naperville, IL
Ron has the Gords, I think Don has an Afco we all know he is a big fan of their customer support. :leghump:
NastyStang113
Made in U.S.A.
Central Florida
I understand that the fitting in the back needs to be ran to the outlet of the electric water pump. The top fitting of the electric water pump goes up to the I/C res. but, where does the fitting that is on the side of the AFCO go? I just need some clarification before I get too deep into it.
NastyStang113
Made in U.S.A.
Central Florida
Any help? I think I've got it all hooked up but just wanted a little clarification. The "side" outlet on the Afco should be going up to the intake manifold. The "rear" outlet on the Afco should be going to the electric water pump, right?
don_w
Dyno Numbers - Who Cares?
San Diego, CA
He was being sarcastic. I have a Gords... I hate AFCO. :321:
racevert
ZKiller
Illinois
I have the AFCO GT500 double-pass HE. When I researche HE available this one had the best numbers and it was a straight fit for the S197.
NastyStang113
Made in U.S.A.
Central Florida
If that's the case than it seems like it doesn't matter which fitting on the Afco goes to the pump and than to the motor. On the GT500s it shows the other fitting on the Afco going to the pump .. Where do you have the other fitting going?
racevert
ZKiller
Illinois
You can go either way. Some say fill from the bottom so the coolant stays in the HE longer. Others are filling from the top. I am pumping in to the bottom fitting from th IC pump, then out the HE from the top fitting to the engine/intercooler, out from the engine/intercooler to the reservoir tank and finally out the reservoir tank to the pump.
don_w
San Diego, CA
^^^^ Same here (with my Gords)
thump_rrr
Montreal Qc,
Is there a reason you hate afco Don?
I was just looking at their radiators and there is quite a price difference between the Afco, Fluidyne, LFP, and Be-cool
ChevyKiller
Preferred Internet Drink
This is the way I had it as well with my Whipple set-up...:hi:
