Blackbird1084
- Joined
- May 15, 2011
- Posts
- 945
- Reaction score
- 0
Ok so last night I was running a buddy of mine when I went to shift to fourth and got nothing. The clutch has only the pressure of the spring holding it out. I could shift the car via rpm match shifting and while in gear, at wot, the clutch held fine with no signs of slipping. I got under the car and looked through the service hole and the slave cylinder was moving in and out ok. I then took off the master cylinder and tried to test it out. What seems to the most common problems for failures on these?
