Part numbers needed
Born To Run
Woodstock,Ontario
I can't find the part numbers for my 2005 Ford Mustang GT
Speed sensor PIGTAIL for Tremec 3650
Clutch safety switch PIGTAIL
Reverse backup light PIGTAIL for Tremec 3650
Any help would be appreciated
Born To Run
Woodstock,Ontario
michael.konor
Georgetown/Fort Hood, TX
An alternative to pigtails is to find a used manual transmission wiring harness, and convert your existing wiring harness for the speed sensor and reverse lights. I've got a 2005-2006 engine harness if you go that route that has those on it.
As for the two clutch safety switches (Deactivator Switch & Clutch Position Switch) the Cable is "C215", you may already have that connector tucked neatly underneath the dash somewhere.
References:
http://iihs.net/fsm/?dir=40&viewfile=Speed Control.pdf
http://iihs.net/fsm/?dir=40&viewfile=Electronic Engine Controls - 4.6L.pdf
Born To Run
Woodstock,Ontario
Part #
References:
Pm sent
