Coolant Boiling out of overflow
W3bb3r04
Slow 3v Member
Clinton, TN
I'm starting to think there's a blockage somewhere but it doesn't make sense that I can blow coolant through the system
W3bb3r04
Slow 3v Member
Clinton, TN
Does anyone else have any other ideas? Im going to try the vaccuum approach if no other ideas pop up.
W3bb3r04
Slow 3v Member
Clinton, TN
Yeah I've tried it on and off as well. Took the upper radiator hose off on the radiator side and while the thermostat was open, there was no coolant moving unless I blew into the overflow or heater hose. I disconnected all the hoses as well and flushed them with water earlier today but it didn't seem to do anything.
deebo05
have you tried filling it without the t-stat and see if it will move water then.
it sounds like you have air trapped in there
you could also remove the crossover and fill each side of the block with coolant.
W3bb3r04
Slow 3v Member
Clinton, TN
No I have not. I have to lift the intake to get the elbow off so I haven't tried that yet. I am trying to think of other ways to bleed the system. Its got to have a big ass air bubble in it if that's what it is.
michael.konor
Georgetown/Fort Hood, TX
Well there are only two things that stop flow. The first is your water pump, but since it was working before and you didn't mention damaging it on installation, we can rule it out. Second is blockage.
Blockage could be anything from installation debris **anywhere** in the engine, including in the block and radiator, or thermostat. And of course a bubble you can't free up.
Just had a thought. Did you by chance change water pump and install one that goes the other direction. Don't ask why I know that....
W3bb3r04
Slow 3v Member
Clinton, TN
I think I may have gotten it figured out. I put a funnel on the overflow, filled it to the top and the pushed the lower radiator hose. Lots of air has come out. Running, it pushes water out of the heater hose lines now. I'm going to get it up to operating temp and see how she does.
AutoXRacer
I am surprised people continue to service their cooling system without a vacuum fill...
These cars are not designed as the old school motors where you just fill it and let her warm up and add till full. You need to vacuum fill the late model cooling systems.
05gtowner
So. Cal
Me either. I just did a 100k mile cooling system overhaul and replaced the radiator, water pump, thermostat and the hoses. Filled it up the old school way and haven't had an issue in the 20k miles since. Not to mention I drive up to the high desert daily for work which includes about 20 miles of driving up hill with the ac on.
I've never had an issue filling a 3V the "old school" way.
Me either. I try not to fix things that aren't broken, lol.
