sportinawoody
all you need is to top off the tank, take an empty antifreeze jug, flip it and put it in the hole and pressurizethe system while running the engine. its a PITA and takes a while but it works. next time OP, just feel your top and bottom hoses. when water is circulating and all air is purged enough to flow, they will feel within 10 degrees temp of one another. if you dont get that, then you still have air keeping the thermostat closed because air is compressible, fluid is notI am surprised people continue to service their cooling system without a vacuum fill...
These cars are not designed as the old school motors where you just fill it and let her warm up and add till full. You need to vacuum fill the late model cooling systems.
