Since my experience with Simraceway phase 2 wasn't a whole lot different from stage 1, I thought I'd combine it with my commentary on the Evolution driving school.
Simraceway driving school, stage 2
This stage involved a few laps around their "autocross" course, which is really more like a mini track than an actual autocross setup, followed by a couple of lead-follow sessions on the track, followed by a couple of normal sessions on the track. I was hoping, actually, for more "autocross" time than we got, since it's a much safer environment to explore the capabilities of the car.
There's not a whole lot different about the track sessions this time than last, except that the speeds were up and I was pushing the car a little harder. The car continued to handle as before, in a very controllable manner. Wear on the tires was a little more pronounced at the outside edges, but not markedly so. I think it's interesting that it took this long to get to the point where the wear on the outside edges was starting to be plainly more than the inside edges. More commentary on this below.
This was unbelievable amounts of fun. They set up what amounts to a real autocross course. Lots of slaloms, lots of tight turns, and even a "skidpad" circle (which amounted to a clockwise 270 degree turn).
There was a lot that I learned from this. In a number of turns, especially going around the "skidpad", I found that I was able to get the car to come back into line by either lifting the throttle and forcing the front to tuck in and, occasionally, getting the rear to step out a little, or by giving it more throttle and causing the car to oversteer slightly and, thus, turn in that way.
I also found that being slow, smooth, and precise on the autocross is still slow. Being truly fast meant driving harder and much more abruptly than I like, and that actually reduced the fun. It may be that it just takes more time to get fast when one is doing so by concentrating on smoothness and precision. We'll see. They're doing another one at the same location in November, and I've signed up for it.
And then there's the tires. While the wear on the outside was becoming apparent after the Simraceway school, this one took it over the top. And it made something apparent that wasn't apparent before. How I drive the track and how I drive an autocross course is very different. On the track, I'm not pushing the car quote enough to reach the limits of adhesion, but I'm still getting a lot of lateral grip per the G meter. On the autocross course, I push the car until it actually does reach the limits of adhesion and, sometimes, even more than that. The latter is much harder on the tires, and it showed after this event. The wear is now enough that I've replaced the front tires to cover the rest of the year, mainly as a precautionary measure. There's plenty of tread on the first set of front tires, at least except for the very outer edges of the tires, so they'll become very useful again once I've got camber plates.
But I most definitely need camber plates. Those, along with coilovers, are going on the car early next year.
Oh, and Dave, since we talked about lateral versus braking grip and "calibrating" the G meter based on that, during the Evolution school I was getting 1.1G of braking, and about 1.05G of lateral acceleration. That I was getting less lateral acceleration than braking suggests that perhaps the way I drive on the track sometimes manages to get more out of the car than how I drive on the autocross. It'll be interesting to see what the G meter says at Laguna Seca.
In general, the Evolution school confirmed my previous thoughts on the suspension of the car. It's very, very good. There may be a little room for improvement in terms of the responsiveness, but I think the current suspension is well past the point of truly major gains, at least until one starts sacrificing major amounts of ride quality to get those gains. I remain pleasantly surprised with how well this suspension works, even in fast transitions such as what you get in slaloms. Of course, it ain't no S2000 or BRZ. Those cars will murder this thing on the autocross simply because they're smaller, and thus can take tightly-bounded corners faster because their line through those corners is shallower and thus faster (slaloms especially will highlight the difference -- you simply don't need as wide an S curve with those cars as you do with the Mustang in order to clear the cones, which means shallower steering angles and thus significantly greater potential speeds).
There do seem to be some steering angle versus speed combinations that result in a lot of understeer, and that's something I'd like to dial back a bit. The problem is, I don't know how to do that without eliminating understeer altogether, and that's something I don't want to do, because most of what I've experienced from this suspension so far is easily controlled balance. My thinking so far (backed by "experience" on the virtual track) is that it's valuable to retain some of that understeer, simply because it allows for greater control over the car. For instance, if you eliminate understeer entirely, then your trail braking is going to have to be very light, else you'll spin the car.
I'm awfully tempted to not change a thing, with the exception of camber plates. But at least with coilovers, I'll have the ability to experiment with various settings to find the best compromise for my tastes. So I'm going to proceed with my plan as it is. I'll continue to work with the stock suspension through the end of the year. By then, I may have discovered some additional things I want to improve. Certainly, stiffening the springs and using better dampers without substantially changing anything else (especially ride height) should yield some improvements here, but what's already there is so good that I don't think those improvements will feel like they're "major".
Another interesting thing of note: this experience has taught me that the autocross venue is a much better place to test changes to the suspension, because you can put the car through most of its handling regime without having to worry about damaging anything.
And one final note, something I found encouraging: the instructors seem to think that I actually have some talent at this.
Laguna Seca is coming up tomorrow, and I can't wait to drive it. I've got many hundreds of laps around it in the virtual world. It'll be very interesting to see how different it is to drive it in the real world. As usual, I'm going to approach it conservatively, and drive the car a little under its limits as I have been at Sonoma. I tend to have more fun that way, because I enjoy being smooth and in control.
