The line between tech and not tech is very blurry for me. I'm kind of "tech blind," like some people are color blind. My misfire detection post is a good indication of this. Car seems to be running rougher than usual, I'm under the hood plugging and unplugging the injectors, listening and feeling the engine change in tone and operation... figure I'd ask why I can notice this but not the ECU...
Glad my technique was the trick, snopro! Here's another good tip, if you are working with bolts you know are going to be tough to remove and if they have a good solid backup (this won't work with something hanging in the air or only supported by sheet metal or something,) you can smack the bolt heads hard with a hammer or hammer and drift before you start loosening them. 90% of the time, for me, it works great. Water pump bolts are a great example.
