Whiskey11
SCCA Autoscrosser #23 STU
- Joined
- Feb 24, 2012
- Posts
- 1,644
- Reaction score
- 4
Soooo... help me wrap my head around this tire calculator nonsense: http://bndtechsource.ucoz.com/index/tire_data_calculator/0-20
If I put in my current wheels/tires (18x9's, 265/40/18 RS3V1's (97W)) and my desired wheels/tires (18x11's, 285/35/18 RS3V2 (101W)) I get less contact patch area with the wider tire. In fact I'd have to run 4 less PSI to get the SAME contact patch area as my 265's give me. I get more width to the contact patch, just less length...
If I run 285/30/18 ZII Star Specs (93W), at the same pressure as the 265/40/18 RS3V1 I get essentially the same contact patch area at the same pressures.
How is it that the shorter and by all accounts stiffer sidewalled ZII's providing more contact patch area than a taller, softer sidewalled RS3V2? Am I missing something here? I see the load index rating for the RS3V2 is higher (101W XL vs 93W) but would that be an indicator for sidewall stiffness?
I mean, ok, I get 30mm more width in the contact patch but I lose 20mm in length. That would seem to imply to me that the 285's will launch worse and brake worse than the 265's will but provide more lateral grip at the same tire pressures?
With 18x10's (a narrower wheel) I get more contact patch with both 285's but the RS3V2 just barely matches the area of the 265/40/18's... the ZII Star Specs get higher than that still somehow?
The only thing I could think of is that the 285's support the load over a wider area so with the same load and same pressure it will see less length to the contact patch. How does this translate into grip then? If we go by these numbers wouldn't the ZII Star Spec technically have better lateral + longitudinal grip abilities (multitasks better) than the RS3V2? It should also grip more overall due to the larger contact patch area no? Given that the ZII is often described as peaky I don't see how it could possibly multi-task better?
On the upside to the shorter ZII SS would also help bring my current 77 mph top speed in 2nd gear down to 72 mph which is at least halfway reasonable.
Help me figure out where to go for tires next year in STU. Also, Dunlop doesn't do contingency, Hankook does. Hankooks are cheaper too.
