ford20
Same here! I could really use a lift to take out my engine lol.
New garbage disposal. Replaced the one that's been there for 8 years. Started to leak from inside due to corrosion and it was a PITA! Disposal key wouldn't break it loose,screwdriver and hammer wouldn't work either. I literately beat the sink into a new position with the hammer and it wouldn't budge. Next step was to get mad,go to the garage,grab a pickle fork and a 5lb hammer and destroy that bitch. About 5 whacks with the pickle fork and 5lb hammer and I won. The frustration was worth not having to pay a plumber a butt load to do a simple job.
If you guys ever run across this issue with a disposal just get a heavier hammer........or a hacksaw.
Those piece of shit Badger brand disposals from Home Depot are not worth the time it takes to install them. My first one rusted out and leaked into the cabinet below the sink after 8-9 years and I never use it. A buddy gave me a replacement for free and I installed it as a temporary measure but it got soaked with spray lubricant and I don't use that sink much. It also has a bucket permanently placed underneath it.
Finally got closet doors up in spare rooms. No idea what happened to original doors. But when I bought the house ALL the closet doors were missing. Wtf.
Also replaced the mailbox. The old one was crooked and the door was broken. Looks better now and I'm sure the mailman is happy not to deal with the old one anymore.
Jaye,
If you actually plan on using that air line instead of just having it there for looks then hang it with bigger loops in the hose. As tight as you have it wrapped you'll spend more time wrapping and unwrapping it than using it. Also the smaller loops mean more twists.
In my garage I have the air line on a 50' retractable spool and in my shop I have the hose hanging from a hook under the bench like yours. But with mine I have the loops hanging almost to the floor so I can pull off what I need with 2-3 loops. But you'll figure that out the first time you use it.
