MT 305/35/20 fitment?
speedfreak1000
2 sided tape expert
Springfield KY
yes I did search put then looking at all the sizes confuses my simple brain and I probably need to tell you my offset but I don't know so i'll probably have to try to find out. just know I have 9 wide in front and 10 out back.
question is if the MT SC 305/35/20's would fit my rear 10' wide rears ok?
I was looking into running the 305/35/20's out back and the 255/35/20's in the front.
if so do you think the sidewalls would look ok in height? if the rears alittle taller than the front would be ok as long as the front sidewall isn't taller.
I could step down to a 275/35/20 out back I just wanted to wide as possible.
here is what it looks like now with no name 275's on the back. I think the cheaper tire makes it look stretched on the rim.
Newman
sumidicsayhuh?
Houston
Yes the will fit, make sure you have the right offset on the wheel of they will rub the fender. My +35 rubbed barely, I would thing anything with a +40 ish or higher should work.
speedfreak1000
2 sided tape expert
Springfield KY
cool, im gonna call the place I got them from and ask them what the offset is.
Thanks Newman
35mm front
40mm rear offsets
dugstang
Atl
I have 40mm rears and they sit flush with the fender. Any tire bulge im sure would cause them to rub. perfect tire ratios on these cars are 265/35 285 or 295/35 rears IMO
dugstang
Atl
eagle f1s are 250 a piece for 285/35..the mickey thomspon 305/35 are only 200ish. Not too shabby for that size. Look at tigerhonakers thread about the mickeys and you will see what they look like on the 10.5 wide wheel. Like I said if your wheel is flush with your fender it will be tough to fit those with lowering springs and not rub on bumps. That's what I feel as im in the same boat. I would like to go to a 305 but will stick to a 285 Michelin as they run wide.
striker 5
here ya go 305 35 20 on 10'' ace rims 255 35 20 on front . No rubbing on rear .
speedfreak1000
2 sided tape expert
Springfield KY
damn, everytime I make my mind up someone throws another thought in it. lol
after dug chimed in I thought yeah i'll just go with some 285's now after seeing yours in thinking just pull the trigger on some 305's and hope for the best cause they look good but then again they look like if I hit a big bump they'd rub...but then I think I don't really hit many big bumps.
speedfreak1000
2 sided tape expert
Springfield KY
hell with, I've spent more on less. I went ahead and bought a set of the MT 305's. I only ordered the back ones because if they don't fit I wont be stuck with 4 tires. i'll see if these fit to my liking then i'll get the fronts to match.
dugstang
Atl
Sweet, im curious how they will look. You could match the fronts with the 275/35 mickeys too. In tigers thread there is a car that has that same stup and looks pretty good.
speedfreak1000
2 sided tape expert
Springfield KY
that was my thinking too dug. thought I might as well try it, if it doesn't work that's fine but if it does it might look good. id like the front to have as much width as I can without it being an issue but still keep the sidewalls about the same height.
19COBRA93
Ford Racing
Clinton, Ut
I'm running 305/35 Mickey's on my 40mm 20x10's, and they fit perfectly. A **** hair one way or the other and they would rub. I'll see if I can find a decent pic.
striker 5
There 40mm 10" wide I have adjustable panhard bar to make sure there centered
19COBRA93
Ford Racing
Clinton, Ut
They're = They are.
There = a location.
Their = Belonging to someone or something.
Just sayin.
Deez-67
Edmond, Oklahoma
