05stroker
Never enough power guy!
Along with the search function, we also have the embed function.
Good for you. Now hopefully we can put to bed that these cars need any gear to be effective as it's been proven time and time again.
And what are your times with the 3.73's? What gains did you have going from 3.73's from 3.15's?I have 3.73's and an auto, no converter. I agree with Brian, its all about the combo of parts.
http://www.allfordmustangs.com/foru...mustang-gt-automatic-w-4-10s.html#post6419994Your not comparing apples to apples now are you?
Grabber Blue 5.0, just curious what your times have been at the dragstrip. Your car is much more heavily modded than mine, so you should be running low 11's @ 120+ at this point. Post up some timeslips for us, please.
My best is 11.2 but I'm usually consistently in the 11.4 range. And no my car is not more modded than yours.
I'd still love to see some timeslips from you to see which of your mods would work best on my car.
3.15 gear
You think running low to mid 12's proves that 3.15's are the right gear? Dude, I spent my evening at our local dragstrip running a bunch of 11.7's and 11.8's with my car while you guys think and hope you might get into the 11's some day.
The "right" gearing for a Coyote automatic can vary depending on the other mods on the car. Simply stating that 3.15's are the right gear for all Coyote automatics is naïve and reckless. Plenty of quick Coyote automatics are running 3.73 and 4.10 gears. Plenty run 3.15's and 3.31's, as well. Again, depends on the supporting mods. Just check the 1/4 mile drag list here in the forums if you don't want to take my word for it. Better yet, get off the internet and get out to real racetracks and see it for yourself.
Pretty impressive times! Who's tune are you using? And what are your shift points? ThanksMost of us don't care to post up our numbers. My best with 3.73 was a 11.66 @116. With 3.15 was 11.60@116. I made about 40 passes with 3.73 I literally gained nothing except for lack of traction.
In my experience the 3.73 were a waste of time. The only reason we did it was my buddy owns a shop and had some sitting there and said let's try them. We took them out and he had used 3.31s it would run 11.6s all day. We get it you like your gearing but for a majority of us that don't have stellar track prep the gears are a waste of time and money.
