5.0 Probie
Around my neck of the woods... The only gas station that does not look like they might rip us all off and put 87 in all three tanks is a Chevron. So that is all I use and have used from the first tank...
Shell 93 no ethanol. I prefer Chevron but none around.
I doubt very seriously there is any publicly available 93 octane without ethanol available in the US as an auto fuel. Either it has ethanol or else it must be labeled as off road fuel/ race fuel/ aviation fuel/ marine fuel. Some stations may not display an ethanol sticker but it still has ethanol in it.
TMS Brian?
There's still some places that 93, 100 and 110 are still available but they are becoming very rare.
http://pure-gas.org/
is it ok to run 100 Non ethanol in our cars? I've been using Sunoco 93 w/10% ethanol and have been seeing 1.75 degrees of knock in my data logs-There's still some places that 93, 100 and 110 are still available but they are becoming very rare.
Exactly..i sent the data logs to Mike and he backed some out...i just hope i can pick up where i left off ET wise...Make sure it isn't leaded and isn't avgas. The specific gravity of avgas is generally less than automotive gas. As a result it has to be compensated for. I'd also check the stoich as racing gas varies depending on what they used to obtain the octane.
Maybe you should take a few degrees of spark out?
