sdleo29
I have a 3650 and will be switching to either a 6060 or T56 once funds become available. If I put in an aluminum 3" DS now can I use it when I upgrade tranny?
I was able to use my Dynotech when switching from 3650 to 6060. Can't help you with dss. A t56 needs a different setup that is unique to it. A splined ds goes into the tailshaft instead of bolting a u joint on like a 3650 or 6060.
Bruce did you use the 6061 3.0 from dynotech?
When I did my 6060 swap, I had to get a GT500 driveshaft (opted out of aluminum at the time) the 3650 driveshaft wouldn't have worked... is the Dynotech an in-between that works on either?
It has a sliding splined shaft. There was enough room for it slide in or out.
