koni / Ford P springs/ stock strut mounts / maximum motor sports Castor camber lates
bullitt boy
NJ
Who has that set up on a 14? Spring does not seem to sit exactly correct in the strut mount.
bullitt boy
NJ
is eibach the only lowering spring that will sit correctly in the stock strut mount? I don't want a huge drop on the car any input is gonna help. Did a search and lots of eibach users claim harsh ride. BMR is an option but not sure if they will go on the stock mounts and the koni yellows don't work with the gt500 mounts.
AMWill
AmericanMuscle.com
Malvern, PA
Hey Bullitt,
I hope I can shed some light on this for you as I ran into this problem myself. To simplify it, if you take a look at my site, there is a really easy way to break down exactly what spring setup will sit in the stock strut mount properly.
Look for the words, "11-14". If you check it out, you see that all of our springs in the 10-14 category will either be listed as "05-14" or "11-14". The 05-14 springs like your P springs are designed for the 05-09 setup but can be used on the 10-14 with different mounts while everything listed under 11-14 will pop right into the stock mounts with no issues.
I run the Eibach Pro Kit on my personal 14 and absolutely love them. Popped right into the stock mounts with no problems and I love the ride and the look.
I would recommend keeping your current setup but swapping out the springs with something like the Eibachs.
Hope this helps and let me know if you have any questions!
-Will
bullitt boy
NJ
Thank you , I ordered the eibach pro kit this morning from AM and was told they will be in Robs performance by tomorrow. Thanks for the info. Any body want to buy a set of brand new P springs?
AMWill
AmericanMuscle.com
Malvern, PA
Bullitt,
No problem at all!
Thank you for your business and support.
Feel free to reach out if you ever need anything, I'm just a PM away.
- Will
cm581978
NJ
Will,
I'm trying to send you a PM but you don't have the PM option listed under your name. Help lol:hi:
Bullitt,
No problem at all!
- Will
AMWill
AmericanMuscle.com
Malvern, PA
Will,
onesillyracer,
Well, let's just pretend like that never happened :thud:.
Thanks for the reply, I am not sure how my private messaging got disabled, but it's back on now :hi:.
Check your inbox, I shot you a PM!
- Will
