Charlie Sheen
Armed and Hammered
I know a few of you have them, what are you using? Location? X or H? Electric or corked? Pics? Vendors? Part numbers?
TIA
TIA
TIA![]()
I have an electric cut out right after the down pipe. The trick is that you have to seal the motor with silicon or rubber or they will crap out under a year no matter what brand you go with.
Andrew
+1... the gate valve no longer closed all the way on mine. There was a little gap, which was no good.....that still doesn't fix the leaking issue though
Thanks for the pic, I think that's how I'm going to do it.Could I just put 1 cutout in my 3 inch downpipe?
wait huh ? seal the motor with rubber ?
ok wait i think i get it in other words the casing for the electric cutout itself ? ....that still doesn't fix the leaking issue though
